What times are 3.7s running with bolt-ons and NO TUNE
Old Jun 20, 2022 | 03:24 AM
JME377's Avatar
JME377
Test pipes, Catback & long intakes. Just trying to see how far I am willing to go before I get a tune. Or do I really need one.
Old Jun 20, 2022 | 07:25 AM
Asking "how far" implies you're not done. What's next? As a general rule of thumb, assuming you're only going to tune once, is to get to the end of your mod plans first. I mean, what else for you is in the works that would impact the tune?
With test pipes, CB and a long tube CAI, you don't need to tune, but would certainly benefit if you did. The car would run better, and there's likely 15 to 20 hp lurking under the curve that you'd like to have.
Times? IDK. No matter what you do with it, without boost it will always be a mid 13 second car.
Old Jun 20, 2022 | 08:21 AM
RMB5190's Avatar
RMB5190
Without a tune, your car is never going to use whatever mods you do in harmony. After installing everything, I went to the dyno and my car was pig rich. Like @Rochester said, I picked up 20whp before 5250 and as high as 30whp by red line. Car drove so much better though - It's hard to describe.
Moderate bolt on's (Intakes, free flowing exhaust), suspension and a tire on a G37 with a tune is about as close to a perfect daily driver as you can achieve. 300+whp, comfortable, handles well, 25+ MPG (pending you right foot), reliable and not a difficult car to work on.
Old Jun 20, 2022 | 09:29 AM
JME377's Avatar
JME377
Thanx man Been trying to decide what to do. I know the tune will be the last thing. What kind of track times did your car get before the tune. Here is my best one.
Old Jun 20, 2022 | 11:06 AM
Said Amir's Avatar
Said Amir
2011 G37xS Coupe
No tune
Muffler delete only: 13.97s
Muffler delete & Test pipes: 13.68s
Tune
Muffler delete, Test pipes, and K&N drop-in filters: 13.44s
Old Jun 20, 2022 | 11:09 AM
14Q60awdSPORT's Avatar
14Q60awdSPORT
Lots of NA FBOs running high 12s, a few even mid 12s on dragy leaderboards.
if you are 13.3 a tune will likely get you 13.0-13.1, some weight reduction and/or a longtube header would push you into 12s.
Old Jun 20, 2022 | 12:10 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Better driveability, throttle response, more "awake" feeling. These were the characteristics I noticed on my bike after installing performance air filter, slip on exhaust and a proper dyno tune for the power commander.
Gained about 20hp at the wheel (~150hp), and ~10 ft lb torque.
Old Jun 20, 2022 | 12:29 PM
For what it's worth, here are my wrap-up comments after last year's remote tune:
https://www.myg37.com/forums/ecu-tun...ml#post4295453
Old Jun 20, 2022 | 05:11 PM
JME377's Avatar
JME377
Originally Posted by Said Amir
2011 G37xS Coupe
No tune
Tune
I ran those same times with filters removed, stock exhaust and shorter tires(255/40/17 Federals 595RS-R). In 40deg weather What was the weather like when you ran that and where are you located. I am in NC
Old Jun 20, 2022 | 10:11 PM
Said Amir's Avatar
Said Amir
Okay, that time is not valid it is basically going downhill. The slop you want to say in 0 to 1%. I am in Texas, and the weather I did those runs was 50-60F.
Old Jun 21, 2022 | 07:24 AM
Is that the Draggy you're grabbing screenshots from?
https://dragymotorsports.com/
Man, I wish I had known about that for before/after review on certain mods.
Old Jun 21, 2022 | 07:56 AM
JME377's Avatar
JME377
Yes It's a good tool to use
Old Jun 21, 2022 | 07:57 AM
JME377's Avatar
JME377
Not all roads are perfectly flat. Not the country roads where I am from. Still ran it. Going up hill on this one
Old Jun 25, 2022 | 06:30 PM
Ponyryd's Avatar
Ponyryd
Guy I sold my Rays to has run high-12s with just bolt ons, bought the rays to run a street slick because he couldn’t hook with his 6m rwd.
Old Jun 26, 2022 | 02:53 AM
JME377's Avatar
JME377
Does he have a tune with those bolt-ons?
