Help Kw v3 question, please help !!
Old Dec 16, 2012 | 08:04 PM
lilvi3tboyzz's Avatar
lilvi3tboyzz
okay, so i found a used set of coil over. And the owner said the thread is messed up and need to rethread. And i found out that a local shop that can does it, only 2 shocks needs to rethread.
Question is, is it safe to ride with the shocks rethread? and should i get it and rethread it?
Old Dec 16, 2012 | 10:21 PM
What threads exactly are messed up? How did they get messed up? This is what I'd want to know before considering buying damaged coilovers.
If they are not dirt cheap, leave them where they are and buy coilovers that don't have stripped threads.
Old Dec 17, 2012 | 08:15 AM
lilvi3tboyzz
the threads on the top of the pillowmount
Old Dec 17, 2012 | 08:18 AM
lilvi3tboyzz
and i think because when they took it off, they over torque it
Old Dec 17, 2012 | 08:52 AM
If it was overtorqued it was done when they installed it, not removed it. IIRC those nuts only need to be tightened to about 27 ft/lbs or so. I wouldn't buy that unless you are going to replace the upper mounts entirely, not just re-thread the studs. I'd be afraid of damage done to the studs and that they may be weakened. I don't know if you can get just the upper mount by itself. Unless you can replace the upper mounts entirely, I'd pass on them and find another used set that aren't damaged or buy a new set. But that's just me.
Old Dec 17, 2012 | 08:54 AM
BosMaSwaG37's Avatar
BosMaSwaG37
I wouldn't risk it.
Laguna
Oct 13, 2015 02:46 PM
Wreckreation
Sep 21, 2015 06:27 PM
GFTW
Sep 19, 2015 03:52 PM
gdaelemans
Sep 15, 2015 12:20 PM
gdaelemans
Sep 13, 2015 09:36 PM
