Help Right Rear caliper piston always sticking
Old Nov 1, 2015 | 10:26 AM
JohnnyS's Avatar
JohnnyS
Exclamation Right Rear caliper piston always sticking
** At a Dead End ** Hello All.... I am at the end of my rope with this problem. Had a rear right inner brake pad worn down to nothing. Changed both rear rotors and pads, replaced and lubed slide pins and still same problem... Caliper piston not re-tracting fully. Then I even changed the whole right rear caliper and the rubber brake line. Still same problem. I cant figure this out. Is this a master cylinder issue at this point? Thanks to anyone that had this same problem and can help. All 3 other wheels totally fine.. I'm out of ideas. 2009 Infiniti G37x sedan. Plain stock single piston rear brakes. ( No Brembo)
Old Nov 1, 2015 | 11:29 AM
Here's the FSM, check link "BR" for the brake system.
http://www.nicoclub.com/FSM/G37/Sedan/2009/
Sure sounds like it's something amiss w/ the Master Cylinder/ABS proportioning
system. Probably best to take it to the dealer, a Nissan shop may be cheaper.
Old Nov 1, 2015 | 12:35 PM
JohnnyS's Avatar
JohnnyS
Right rear caliper sticking
Thanks so much for the reply. Yeah I think its time for the dealer as I am out of ideas. I found some "ask an Infiniti expert" internet site that will answer my question for $18 but I think at this point I'm throwing good money after bad. Whats he going to tell me anyway that its an ABS issue. I cant fix that anyway!!
2011G37JOHNBEST
Jul 8, 2016 05:28 PM
Zukauskas
Buying & Leasing
Oct 17, 2015 09:30 PM
JakeG37
Oct 17, 2015 11:43 AM
slotterjordan
Oct 15, 2015 02:50 AM
perfectmax
Oct 5, 2015 07:24 PM
