OEM Infiniti Enkei 18x7.5 SQ Wheels Clear Akenono BBK
Old Feb 11, 2023 | 03:23 PM
Krzysztof47's Avatar
Krzysztof47
Just wanted to make this post to help others looking to do the Akebono BBK.
I had a lot of trouble figuring out what OEM wheels would clear the factory BBK. People said you need 19's, a certain width, etc. My G came with 17x7.5 wheels in a square setup and I did not want to run a wider wheel or have some ridiculous offset and run into steering rack issues with clearance etc. I also did not want to run aftermarket wheels that would need spacers or hub rings, too much of a headache.
The OEM Infiniti Enkei 18x7.5 square wheels clear the BBK without any spacers and work well. This way you can run the appropriate tire size coming from 225/55 R17 to now 225/50 R18 with out messing with the speedometer too much.
Props to: @2012G37 for helping me confirm the BBK clears the Enkei's and helping me out a lot!
The OEM part number for these Enkei Square wheels is: D0C00-1NH4A
For the spare wheel, I am using the Enkei 18X4 spare donut which clears the front and rear BBK and fits into the spare tire section in the trunk without any issue.
Here are pictures of my setup, the front clearance as the rears easily clear. Still plenty of room.
https://imgur.com/RsqhbzS
https://imgur.com/npFbxEy
Hope this helps someone out there!
Old Feb 11, 2023 | 04:18 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^G37S sedan came stock with 18 x 7.5" (225/50/18) in the front which clears the stock 4 piston akebono brakes (bbk). Rear on said car was 18 x 8.5", 245/45/18 stock tire.
So it sounds like those are the wheels you're after.
FWIW, for winter wheels, I ran 18x8 with a 225/50/18 tire, square.
Old Feb 11, 2023 | 04:31 PM
Krzysztof47
Thank you, I am running 18x7.5 Square with the BBK. AWD models do not come with staggered wheels. Made this post to show it clears.
Old Feb 11, 2023 | 08:17 PM
2012G37's Avatar
2012G37
Glad it worked out well for you. I know the OEM dust shields which comes with the AWD won't fit or fit properly with the new set up. Did you install the ones which comes from the Sport RWD?
Old Feb 11, 2023 | 08:26 PM
Krzysztof47
Great question. Yes I did install the front OEM sport dust shields that come from the RWD models. I did this because I had scrapping issues and did not want to play musical chairs with having them trimmed. I would not even call them dust shields as so much is cut away from them. I had the rears trimmed and they clear but I somewhat wanted to put the sport rear dust shields on as that would be the proper way to do it.
The fronts you need to take the wheel hub off and use new axle nuts. Not really a big deal, the rears you would have to disassemble the parking brake which should not be bad but that is a whole lot of trouble to go through to replace a flimsy dust shield. Not to mention new axle hardware for the rear as well as well as taking the rear wheel hub bearings off.
G37X GraSdadow
Jul 29, 2016 06:37 PM
ck1109
Oct 15, 2015 11:06 PM
Ryno23
36
Jun 4, 2014 10:14 PM
mystakin
Aug 14, 2011 12:38 PM
rks
Oct 14, 2010 02:47 PM
