Top mounted hanging pedal conversion
Old Feb 15, 2023 | 05:46 PM
AMP_01's Avatar
AMP_01
Hello all!
New here, and have been looking at the G37 manuals as the car is pretty much everything I want, except one tiny problem.. I hate floor mounted pedal. I've driven them before and I always get irritated with them for some reason, so I'm not a big fan. Has anyone ever done a conversion for the floor mounted pedal to a hanging top mounted pedal?
Old Feb 16, 2023 | 08:22 AM
BULL's Avatar
BULL
Moderador
Originally Posted by AMP_01
Hello all!
This might be a bit of a mission for you. The G/Z pedal for dual throttle V6 is an assembly on it's own. Part of the accelerator electronics are part of the pedal while the other side is part of the sensor. In previous years you had a double channel TPS sensor mounted to a metal pedal. The voltages are different.
In reality you'd have to find a similar pedal, maybe something from another Nissan, maybe around those same years. It is unknown if an accelerator pedal from the same brand from a single throttle vehicle will work with yours or even self calibrate correctly but its up to you to figure it out. Many people actually like the floor mounted pedal. It's actually common in the sport world and racing too.
Before you go into this endeavor You should try taking yours off and cleaning it as well as putting some silicone grease around some of the plastic to plastic surfaces.
I had to so on a pedal I bought from the Junk Yard. It might decrease some of the friction and get you to change your mind over this.
Even with swaps folks have to use this pedal so plenty of folks.
This will be a completely waste of your time and money over a simple behavioral change.
Old Feb 16, 2023 | 01:37 PM
Rik R.'s Avatar
Rik R.
I certainly wouldn't try to retrofit a top-hinged pedal. But, you could try an RJM unit, they come highly recommended:
https://rjmperformance.com/370z-g37/
I am going to pick one up soonish and install it.
Thanks,
Rick
Old Feb 16, 2023 | 03:55 PM
BULL's Avatar
BULL
Moderador
Thanks,
Rick
The only type of floor mounted pedal is the accelerator pedal which is the pedal the OP wants as a hanging one like previous models.
Old Apr 30, 2023 | 01:21 PM
AMP_01's Avatar
AMP_01
Yes I really want one this is my first floor mounted pedal car and I am going to be honest...
It is DIFFICULT to use my whole foot I am not used to it at all I have been driving this car for about 2 weeks now
Old Apr 30, 2023 | 01:22 PM
AMP_01's Avatar
AMP_01
I really am not used to the floor pedal I still use the ***** of my foot to accelerate rather than my whole foot and it has been 2 weeks haha. It's weird because it feels like I have to press it more to get to the same revs as I would in a hanging/top mount pedal.
Old May 2, 2023 | 02:09 PM
BULL's Avatar
BULL
Moderador
I get what you mean. I typically rest the heel and use the big toe for acceleration.
It's easier and cheaper to correct behavior than to go down the pedal route.
The OEM pedal cannot be separated from the sensor
APP sensor interacts with almost every module in the car
Finding a spot on the inside of the firewall to mount the pedal will be a nightmare
Expect possibly to be a $500 job. $300 average for if such pedal exists and $200 labor.
Hopefully those prices can get your subconscious to calm the F down and learn something new.
On another note, learning how to drive with a floor mounted pedal will help you drive other vehicles, especially in the exotic and supercar world.
Eric66
Jan 29, 2018 03:59 PM
akiradavis
Jun 19, 2016 12:07 AM
Muujig612
Apr 30, 2014 08:11 PM
ANMVQ
Jul 24, 2011 07:04 PM
