GOT THIS PROB? G37s - Service Engine light on - Idling 1000 rpm - NO CURE?
Old Apr 1, 2013 | 09:57 AM
Bigbodyg's Avatar
Bigbodyg
Exclamation GOT THIS PROB? G37s - Service Engine light on - Idling 1000 rpm - NO CURE?
hi guys
my 2009 G37s (and another customers as well) has been in the shop for over 1 week (and prior 2 other visits as well) for a SES light coming on - which they cant find the cause of. Only issue is its buring major gas and idling at 1000 rpm. (also started engine stuttering now - and i only fill up Premium gas)
They have the Infinti TECH guys from their TECHLINE working on it now - and wants the cars for a week or so (gave me another G as a loaner )
ANYONE ELSE HAVE THIS?
Old Apr 3, 2013 | 02:22 AM
unknowndesi's Avatar
unknowndesi
Have you ever cleaned your MAFS? I had a similar issue, after inspecting the MAFS I found dirt on them. On some occasions my car wouldn't even start (usually after a rain fall or extremely humid weather).
Old Apr 3, 2013 | 05:36 PM
Bigbodyg's Avatar
Bigbodyg
yes i have - but if it was the MAFS it would show up in the readings... also my modded g and this stock G have the same prob.
Old Dec 8, 2013 | 10:09 AM
rodrich's Avatar
rodrich
Did they figure out issue? Mine was solid.. Then blinked and car choked. I had oil leaks in the spark plug tubes. Very expensive fix. However now light is on solid and goes off sometimes when I fill gas tank.. Very weird. Infiniti doesn't know what it is. They say it could be a short in wiring harness if it does this off/on cycle. I don't want to spend more money with them guessing..
Old Dec 8, 2013 | 03:53 PM
Bigbodyg's Avatar
Bigbodyg
Well funny thing, they did figure out last year when this happened - it was a computer replacement was needed (as another G was in for the exact same issue at the same time) well lone behold, just last week i had the same issue AND THE OTHER G WAS ALSO BACK IN!!!
So they erased the code, and sent me back too see if it comes back (it hasnt yet) and they are testing the other guys car (they put a computer in his car to track the computer reading while he drives) to find out the issue and will call me back.
Thedbarz
33
Feb 9, 2016 12:05 AM
vquezada24
Nov 20, 2015 04:51 PM
SS2006
Aug 11, 2015 10:24 PM
Ali K.
Aug 5, 2015 11:49 PM
