Strange window behavior
Old Sep 12, 2012 | 11:13 AM
jmann's Avatar
jmann
Yesterday I had run to home depot to pick up a propane tank refill, and since I used the automated machine outside I left the windows rolled down and the trunk open. I turned the car off, got my refill, closed the trunk, got in, started it and rolled the windows up, but before the went all the way they both reversed and started rolling back down again. This is on a 2012 coupe with 1800 miles on it BTW. When they started going back down I held the switch in the up position until they closed and they stayed closed. I then tested a full opening and closing and it appeared to work correctly. Is this a common problem? I have tried searching but have not found anything exactly like this being discussed. I know how to reset them by holding the switch up for 5-10 seconds after they are closed, but I haven't had to do that and the battery has not been disconnected. I just found it strange and hope it is no indication of problems to come later.
Old Sep 12, 2012 | 09:42 PM
Brian Thompson's Avatar
Brian Thompson
That's only ever happened to me if I unplugged the battery. If it happens again, I think you should take it to the dealer. They might not be able to pinpoint the problem, though.
-Brian
Old Oct 8, 2012 | 12:57 AM
Zydan's Avatar
Zydan
I have a 2012 with 2400 miles, has happened a couple of times to me, but both times I just pushed it up again and went all the way up.
Hasn't really seemed like anything to be worried about.
Old Oct 8, 2012 | 07:21 PM
winkerbean's Avatar
winkerbean
I have an 08, when i roll the windows up with the one touch feature they go up and then roll back down about an inch or so and stay there. happens every once in a blue moon. doesn't happen enough for me to find a solution
cellwoot
Sep 7, 2018 07:10 PM
RexHavoc
Oct 2, 2015 11:47 AM
CiViCKiDD
Sep 24, 2015 10:47 AM
Wreckreation
Sep 21, 2015 06:27 PM
