Help No Heat...
Old Nov 14, 2012 | 10:41 AM
Only4theGnme's Avatar
Only4theGnme
No Heat...
I have an older second car...a Honda Accord...not sure of the year, I think 98 (it's my Aunt's).
I noticed towards the end of the summer the AC was fading and not getting as cold. I didn't worry about because it was nearly Fall. But now I am noticing the heat no longer blows hot air...not even warm. Is this most likely the Thermostat?
Old Nov 14, 2012 | 10:55 AM
g37guy01's Avatar
g37guy01
Look at the temp gage. If its not in the 'normal' zone for the car it probably is the thermostat. If the temp gage is normal maybe have a blocked heater core.
Old Nov 14, 2012 | 11:26 AM
Only4theGnme
Ok, cool. Thanks.
Old Dec 10, 2012 | 09:45 AM
Only4theGnme
beathorse
Old Dec 10, 2012 | 01:29 PM
juicybusa's Avatar
juicybusa
Originally Posted by Only4theGnme
Ok, cool. Thanks.
Could also be that the coolant level is low-this can cause a no heat situation-also an air pocket in the cooling system can cause this if not purged when the coolant is changed.
Old Dec 26, 2012 | 04:01 AM
DeamonG37s's Avatar
DeamonG37s
Coolant level check your rad cap.
therzdae
Aug 1, 2019 10:38 PM
