HVAC switching on its own
Old Nov 6, 2012 | 08:56 AM
CoolBreeze's Avatar
CoolBreeze
I manually turn my heater on. The mode is for the floor vents. After driving around, the mode switches on its own to the vents. I manually switch back to the floor vents.
Driving some more, the mode switches on its own to defrost, and the A/C comes on.
I did not use the Auto setting turning on the HVAC, and when toggling the mode back to the floor vents, I did not toggle the defrost setting.
Has anybody else experienced this? Is there some HVAC operational setting I am missing? TIA
Old Nov 6, 2012 | 08:58 AM
jarvo's Avatar
jarvo
In my G35 my heat/AC would turn on full blast and I would have to punch the stereo until it was able to turn off.
Haven't heard of this being much of a problem in the G37's though.
Old Nov 6, 2012 | 10:45 AM
dkmesa350z's Avatar
dkmesa350z
I hate how it switches to fresh air by itself when you have it set to recirculate. haven't figured out what prompts that. My Z did it all the time too.
Old Nov 12, 2012 | 09:54 PM
venkatsharat's Avatar
venkatsharat
hmm. thats wierd.mine does not do it.
Old Nov 15, 2012 | 09:32 AM
CoolBreeze's Avatar
CoolBreeze
@jarvo
Wow, I did not realize Infiniti ties their HVAC into the stereo.
I take it you pump the bass for more heat and crank the treble for more A/C.
Does the fade adjust the front/rear air flow and tweaking the balance accommodate the passenger?
vamarris
Dec 9, 2018 11:10 AM
Upscale Speed
Dec 26, 2015 08:45 AM
parkern
Oct 1, 2015 10:15 PM
CiViCKiDD
Sep 24, 2015 10:47 AM
steven92
Sep 23, 2015 08:48 AM
