Squeak Under acceleration
Old Apr 9, 2013 | 05:39 PM
Fico's Avatar
Fico
I did some searching and nothing matched what im experiencing so im hoping someone can help.
G37X 2010 with 17k miles on it and bc coil overs
it started off last fall and wasnt to bad but it has become progressively worse.
when accelerating from a stop or lower speed cornering i get a loud defined squeak verging on a screech from what sounds like the rear drivers side (it could be passenger but im obviously on the drivers side more)
i dont know why but i think its the differential or transfer case but i havent had anyone look at it and have no basis for my opinion.
i did take it to a track day once last year and had just about every warning light on including the AWD which went off shortly after it was on.
I drive quite aggressively around town and tend to beat on it more then most care to admit.
has anyone heard a similar noise? ill see if i cant get a video or sound clip to share.
please let me know what you think.
Old Apr 10, 2013 | 10:52 AM
SwissCheeseHead's Avatar
SwissCheeseHead
Check your brake pads. There is a wear indicator when they get low. You admit to driving it hard, which leads me to believe you brake hard. That would be my first guess. Also, BC coilovers are known to make noise. It could be something to do with your suspension.
Old Apr 10, 2013 | 11:06 AM
Fico's Avatar
Fico
hmm ill check the coil overs but all the pads are brand new. thanks for the input!
Old Apr 30, 2013 | 07:12 PM
Fico's Avatar
Fico
just for archival purposes,
figured it out, the bracket at the end of my exhaust was cutting into my driveshaft heatshield. the sound got worse the more it broke through.
i either drop the exhaust and remove the heat shield, or let it sound a bit bad for another bit while it clears a hole which i can help widen
Old Jun 7, 2013 | 03:47 PM
Fico's Avatar
Fico
and I lied.....
it came back (seems dependent on how warm the weather is) but here is a video, please disregard my dumbass talking lol
http://s27.photobucket.com/user/vibr...62520.mp4.html
Old Jun 11, 2013 | 08:05 AM
Fico's Avatar
Fico
Any ideas? infiniti has had my car for a week and is having no luck
Old Jun 11, 2013 | 02:06 PM
Fico's Avatar
Fico
VID_20130524_162520.mp4 Video by vibratingcow | Photobucket
there is the video in working order
Old Dec 31, 2015 | 05:57 PM
shamby10's Avatar
shamby10
i know this is an old thread but i too have the same problem. i watched the video and thats what mine sounds like. I keep thinking its the rear diff or drive shaft, i hope you found out the issue
misc
29
May 24, 2023 03:57 PM
parkern
Oct 5, 2015 12:12 PM
timc00k
Sep 25, 2015 12:35 PM
Simm0nS777
Sep 24, 2015 08:19 PM
T_Buckets_223
Sep 8, 2015 09:49 PM
