Help Removing Oil filter problems
Old Nov 25, 2012 | 08:44 PM
jms493's Avatar
jms493
Question Removing Oil filter problems
I have a 12 G37 AWD. All my filter wrenches are too big and I can not get the oil filter off by hand. It is too tight and was put on by the dealer.
Does anyone have a suggestion for an oil filter wrench that will work for this car?
Thanks.
Old Nov 25, 2012 | 09:10 PM
If you remove the under tray completely you should be able to grip it pretty easily with both hands. Put a couple of wide rubber bands around it (like the ones you get off of fresh broccoli), grip tightly, and get it off. If you can't do that, you can stab through it crosswise with a long screwdriver and have handles to turn it off. Or you can go into any auto parts store and get a replacement filter to gauge the size and get the correct wrench based on that.
Old Nov 25, 2012 | 09:18 PM
jms493's Avatar
jms493
yeah i thought about stabbing it with a screwdriver. I will just go to the store and look for right size wrench. Not a huge deal that I didnt change it but I have always changed the filter when changing oil.
I did remove the undertray enough but could not get it off or get anything to grip it. I wish it was bigger so my old wrenches would work
Old Nov 25, 2012 | 10:53 PM
rlo's Avatar
rlo
If you go to any auto store you should be able to find an oil filter plier
http://www.oildepot.ca/wp-content/up...er-wrench1.jpg
It essentially crushes the filter but lets you get a good grip to unscrew it. Its one use if you intend on DIY oil changes.
Old Nov 25, 2012 | 11:31 PM
TVPostSound's Avatar
TVPostSound
The fact that you can not remove it with your hands is not an issue, it's actually good!
This is typical, even for a hand tightened filter, that has the gasket oiled before installing.
Stabbing the filter or using crush pliers should be a last resort.
Get a band style filter wrench that is properly sized, it will come off fairly easily.
Don't forget to rub some clean oil on the new filters gasket before installing.
Old Nov 26, 2012 | 05:14 PM
telcoman's Avatar
telcoman
Thanks.
You need one of these
You need to remove the fiberboard shroud underneath the car
You can also use a end cap wrench. I only use it to tighten the filter 1/8 turn after it is hand tight but you can also use it to remove the oil filter.
Use a 3/8 inch drive socket wrench
Telcoman
Old Nov 27, 2012 | 01:19 AM
JSolo's Avatar
JSolo
Just say no!!!!!
I have an older filter wrench that fits the small diameter GM filters. These filters are slightly larger diameter than the g37 filter. A small length of heater hose cut long ways to fit in between the wrench and the filter does the job.
Old Dec 1, 2012 | 10:07 AM
SwissCheeseHead's Avatar
SwissCheeseHead
I've had this happen to me on older cars. It'll come off. Just breathe, curse, squeeze and turn and it'll give. the broccoli-band is a great idea. Good times
Old Dec 9, 2012 | 03:50 AM
unknowndesi's Avatar
unknowndesi
This is what happened when I tried to put a hole into a cheap china filter in my brothers van. I literally had to take needle nose pliers and stick them into those tiny drain back holes and use a pry bar to get this damn thing off. Use a filter wrench or socket, use the screw driver hole method till the end.
Old Dec 10, 2012 | 06:53 AM
The real root of the problem - stop putting oil filters on that tight. Lubricate the rubber seal on the new filter with some oil. Screw it on until the seal touches the seating surface. Only tighten another 2/3 to 1 full turn. That's all you need. It won't leak. Putting it tighter won't accomplish anything but making it very difficult to remove.
Old Dec 12, 2012 | 02:00 PM
cl335's Avatar
cl335
this is usually the best solution to any problem lol
Old Dec 19, 2012 | 11:45 PM
CodeG's Avatar
CodeG
Channel lock plier, works every time..
Amaadkhan2k
Oct 4, 2024 01:20 PM
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
slawek65
Sep 8, 2015 09:07 AM
ZachThomas
Sep 3, 2015 01:40 PM
