Windshield Wiper Sprayer problem
Old Oct 16, 2012 | 12:35 PM
GeezerB's Avatar
GeezerB
Tried the windshield sprayer that is supposed to activate with the wiper switch (pulled it toward me), but nothing comes out. I don't hear the motor & no warning lights are on. Is there a fuse to check or other trouble shooting I can perform? My G is only 3 months old & this is the first time I tried this.
Really don't want to return to dealer for such a small problem.
Old Oct 16, 2012 | 12:49 PM
shivers's Avatar
shivers
may be a silly question, but does the tank have washer fluid in it?
Old Oct 16, 2012 | 01:17 PM
GeezerB's Avatar
GeezerB
If it was empty, would I get a dashboard warning light?
Old Oct 16, 2012 | 01:24 PM
GeezerB's Avatar
GeezerB
From the manual:
11. Low washer fluid warning
This warning appears when the washer
tank fluid is at a low level. Add washer fluid
as necessary. (See “Window washer fluid”
(P.8-16).)
Old Oct 16, 2012 | 02:13 PM
bythabay's Avatar
bythabay
20 Year Member
I've seen a few of these fail on the newer Gs... Try listening to the motor while spraying, if you don't hear anything, it is likely there is an electrical problem related to wiring or a bad motor.
Old Oct 16, 2012 | 02:14 PM
bythabay's Avatar
bythabay
20 Year Member
Ah just noticed you don't hear the motor Well next step would be to test the terminals at the motor connector to see if you are getting voltage when activating the motor.
Old Nov 3, 2012 | 04:57 PM
playdjembe4god's Avatar
playdjembe4god
Mine only spray out of the middle holes.
Old Nov 6, 2012 | 10:06 AM
TeeItHi's Avatar
TeeItHi
mine only 3 of 4
my far right (passenger side) don't work.
Old Dec 7, 2012 | 05:58 PM
GeezerB's Avatar
GeezerB
I know this is a useless reply but I tried this again after a heavy rain & it worked fine. Maybe I just needed to break in my wipers
Old May 28, 2013 | 03:27 PM
unknown2k1's Avatar
unknown2k1
I know this is an old post but how did you make it spray from all the wholes. I feel like mine has gotten weaker and i thought it sprayed across the windshiled but its not coming out of two holes.
Old Mar 19, 2019 | 11:29 PM
Infinibini's Avatar
Infinibini
The hole got plugged up!
butwhatuptho
Oct 4, 2015 07:51 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
