Engine swap
Old Feb 28, 2024 | 08:14 PM
AV37's Avatar
AV37
Engine swap
Hey guys I have a 2009 g37x sedan and I recently found out my engine has gone bad due to the gallery gasket problem, I’m looking into swapping another engine in but I realized that the labor is very costly and thought it would be worth trying myself. Has anyone posted a guide on how to do an engine swap for this car? I appreciate the help in advance
Old Feb 28, 2024 | 08:35 PM
Krzysztof47's Avatar
Krzysztof47
Whatever engine you swap in, better put in the updated gallery gasket in or it will be a lost cause.
People say the updated one was introduced in 2012 and up, but it really was fully introduced in 2014 engines I believe.
Old Mar 1, 2024 | 01:52 PM
AV37's Avatar
AV37
Yeah I was advised of that, where can I get the updated one from?
Old Mar 1, 2024 | 08:38 PM
Krzysztof47
Upper gasket is: 13533-JK21A
Lower gasket is: 13533-JK21B
Gallery covers (2x): 15066-JA10A
Z1 Kit: https://www.z1motorsports.com/front-...75437eb9ad0a44
I have a spare brand new upper and lower gasket if you are interested.
Old Mar 4, 2024 | 02:39 PM
camopaint0707's Avatar
camopaint0707
An engine swap is essentially the same in every car. Bellhousing bolts, wiring harness, ps lines, fuel lines, heater core, ac compressor, torque converter bolts if you have it, intake, engine mounts. lift up and remove.
Old Mar 12, 2024 | 01:31 AM
AV37's Avatar
AV37
Do y’all know if an engine from a RWD car would fit on my AWD? If read conflicting things? Also would later year engines work as well? Trying to filter my search so that I’m left with ones I know will def fit
Eliseo
Apr 24, 2025 01:14 PM
Slo_G
Mar 8, 2024 10:51 AM
kbrow173
General Tech Questions
Dec 30, 2021 02:44 AM
roylan
May 27, 2021 06:18 PM
G3sevenn
Feb 28, 2020 09:21 AM
