- G37 Intake and Exhaust suggestions?
- R2C short ram VS Takeda CAI
- Deeper Tone?
- First mod - K&M intake on a 2011 G37x
- Takeda CAI hydrolock water concern
- Do I need a tune???
- What's your "buy" price on a used R2C?
- Exoticspeed exhaust with Z1 HFC's.
- IPL Axle-Back Exhaust Portion
- CAI on G37
- Exhaust Suggestions 08 G37S Coupe
- Intake Vs Exhaust
- Those of you with FI CBE and FI RHFC
- Fast Intentions Length Issue? Brace?
- Help! Test pipe bolt snapped in half
- 07 G35x Catalytic converter rattle
- Can't unclip MAF sensor?
- Fast Intentions HFC Gasket Question
- Help long tube headers or stillen headers?
- Review Stillen exhaust vs stock comparison (with video)
- Help What test pipe/HFC are you running?
- Test pipes with Muffler delete
- RHFC Clearance/Ride Height
- Question About Air Intakes - Restriction vs Temp
- Any one have this setup....
- Lubricating Rubber Exhaust Mounts - What product do I Use?
- Cold Air Intake
- 1st Gen vs 3rd Gen Stillen intake
- Whats the best Air Intake for our G37
- Stillen 3G intake vs R2c intakes for my g37?
- Straight Pipes?
- ARK exahust question
- stillen cat back question--provide input if you can
- Removing right intake to clean throttle body
- K&N air filters causing CEL ?
- Which exhaust hangs lower at the mid pipe, OEM or Ark Grip?
- z1 plenum
- test pipe non reasonated with stock exhaust
- Help with exhaust
- High-Flow Catalytic Converters and Emissions
- mxp or fast intentions
- Test Pipes vs RHFC
- Topspeed Pro 1 Question: Inlet Diameter?
- Which air filter brands are of good quality yet cheap?
- mishimoto or hps post maf tubes
- Top speed intake?
- Do you have the HFC hiss?
- stock air box
- High rpms while car is in drive gear
- Less Rasp Between H and X pipe?
- New Bored Out Throttle Bodies!! HP & TQ Increase!
- K&N oil filter or AME dry filter
- Enthusiast recommendation on exhaust situation
- axleback install
- check engine light off?
- Install ark grip exhaust meant for coupe on sedan
- Longtube headers vs shorty and test pipes
- Test pipes decision making help please :)
- Aftermarket HFC's damage O2 sensors?
- Exhaust Comparison
- Best intake to increase MPG
- Help Squeaking After Exhaust Install
- MXP vs ARK vs HKS
- Somebody please help me with p2a00 code
- Low-Budget exhaust mods
- New exhaust system
- Just ordered FI CBE
- Test Pipes ?
- Fast intentions exhaust tip adj
- NEED HELP!! Exhaust system
- Help FI-Resonated Test Pipes w/ Motordyne E370 Exhaust
- Air Intake
- Fast Intentions cat back exhaust (Help)
- question for those with IPL exhaust
- Exhaust Recommendation
- New exhaust, need opinions
- Aftermarket Exhaust rating sould levels. Looking for a sedan catback
- Dont waste your money on intakes! Read first
- CAI's
- Help Does ARK 370Z exhaust fit G37?
- Help About to buy an exhaust system and Y pipe
- Stillen Gen3 grille shield?
- Intake Tube
- Stock intake box mod?
- Throttle Body Spacer
- Intake color dilemma - suggestions?
- Stillen Headers AND Berk HFC Question
- My thoughts on MXP catback
- High Flow Cats
- Help replacing the ac line
- Help Ark exhaust adjustment.
- Art Pipes installation help needed!
- Ses bank 1 sensor 1 fi rhfc
- CARB legal catalytic converters
- Z1 High Flow Cats with Tanabe Medallion
- Z1 HFC's
- Help HFC's- Choices
- M2/Ebay Axle Back Exhaust video clip on G37s vert
- Fast Intentions RHFC with Stillen CBE?
- Exaust that doesnt sound like rice....
