- Fast Intentions high flow cat failure
- Resonated test pipes
- Best test pipe paired with invidia Gemini cat back
- CEL after Takeda intake install
- Help Nismo muffler on g37x coupe
- Pros and Cons, Axel back or muffler delete?
- Invidia test pipes. Flame shooter?
- Muffler delete
- 3" exhaust
- Check engine light after intake installation
- How to get more sound out of Sedan on the budget.
- Help Help e370
- Muffler Delete + Aftermarket Resonators?
- G gave birth to dual cat heatshields
- service engine soon light after berk test pipes installed
- Where can i find R2C panel filters?
- Megan mid-pipe (not y-pipe)
- Interest in K&N velocity intake kits
- What is that plastic thing on the sedan' mufflers?
- Resonated Exhaust Tips
- New Intakes: Could I, Should I, Reset the ECU?
- Berks test pipe install
- Fast intentions swap
- Custom true dual exhaust and HFCs (Video inside)
- Nismo R-Tune intake installed on IPL
- R2C Intake installed on my IPL
- OEM intakes
- Any resonated Y Pipes for the X Sedan?
- DIY VQ350HR manifold for the VQ37VHR
- Stillen Gen 3 replacement filters
- Greddy Revolution RS exhaust
- Need HELP! Intake installed, now have codes!
- For those with ART pipes and Motordyne exhaust...
- Ses
- Dyno tune required for k&n air intake?
- Long tube headera install
- FI coupe RHFC on a g37 sedan
- aam cold air intakes
- Question about Takeda CAI
- Stillen cold air intake gen 3 370z same as g37?
- Will 35HR test pipes fit my car?
- Why are my stock exhaust bolts welded on? (see pics)
- Berk High Flow Cats.
- Review: Fast Intentions High Flow Cats & Catback Exhaust
- 08 g35x intake install help
- Are these actually berk hfcs?
- Pre R2C Install Advice
- Dremmel for intake
- Quick question guys about an intake
- Just installed invidia gemini cat-back
- Help straight pipe and muffler delete
- Part number needed
- Help GarageLine X-pipe & Midpipe Question
- Long Tube Headers
- Question about catalytic converters!
- Fast Intentions Resonated HFC
- Z1 Intake Mod
- Crushed 02 sensor clip
- Motordyne E370 Exhaust for AWD?
- Need help (check engine light)
- motordyne m370
- Building my own RHFC for half the price of FI or Berk..
- Black paint coming off oem exhaust cans. covered under warranty?
- Sedan exhaust
- Sedan Test Pipes & Muffler Delete
- SES Light on since taking out stock intakes?
- GTHAUS axle back
- Exhaust fitment questions, particularly the Y-Pipe.
- Meisterschaft Axel back + Mid Pipe + Blank Option
- R2C Panel Filters?
- Passing Emissions Test with the GTHaus Exhaust?
- Help Ark grip exhaust G37 sedan
- Which intake? Stillen gen 2 or R2C?
- Made the demon bolts my be-atch :)
- R2C intakes 3/14
- Help new g37 owner looking for upgrades
- Throttle Body Cleaning Torque Specs etc.
- muffler delete + resonators delete + test pipes?
- AEM cold air intakes (from 370z nismo) Dyno
- Motordyne e370
- Muffler delete or Resonators delete?
- Planning to install FI RHFC to my OEM exhaust
- Replacement air filters for Status Elite
- stock g37 sedan NEED OPTIONS
- axle back modification - Anyone try this?
- after market air filters
- Air Filter Factory vs Other
- Cheap Takeda Cai intake!
- Air intake suggestions
- Got my double dongs but now i have a question
- Cat-Back Exhaust System
- Hole in Stillen Gen 3
- Input on your Intakes
- Will I run too lean with HFCs
- Sedan Axle back exhaust options(clips please)
- Needing a little bit more sound out of my exhaust
- Berks HFC Question
- Stillen Gen3 causing over heating?
- FI Resonated Cats Question
- Magnaflow x pipe vs
