- Help Another exhaust diameter thread
- Random thought: G coupe exhaust same as EX35?
- Ark exhaust + isr resonated test pipes. Anyone ?
- Wanting to buy an exhaust, but which one? Invidia vs HKS
- G37S OEM exhaust differences
- Help Badly stripped demon bolts
- Help Test Pipes Vs. Long Tube Headers
- Help Cold intake
- Which Exhaust Would Recommended
- ISR LTH CEL - Help
- Help Will 350z exhaust fit g37 coupe?
- Resonator delete on sedan
- ISR LTH for 09 Sedan?
- Help Question about performance Y Pipe install 2012 g37x
- Throttle Bodies & Intake Manifolds
- Help Test pipes installation
- Help Best Valve Exhaust Setup
- Help Silly question for a new modder
- Exhaust identification.
- Long tube headers and O2 Sensors
- Stillen CBE
- Help HFC with stock y pipe and manzo exhaust?
- Is it a good idea to heat wrap test pipes?
- Stillen Long Arm intake in the rain?
- Help Thinking of Admin intake, what other considerations?
- Ported Upper and Lower Intake Manifolds - Good or Mediocre?
- 1320 performance for g37
- 3.5'" intake
- Exhaust Rasp Help!
- Resonated test pipes vs non resonated HFC
- Top Speed Pro 1 Longevity?
- Help Looking for ISR resonated test pipes
- Help RPM limiter in N and testing decibels
- CAI/Intake Manifold/Headers Sizing
- Intake Resonator? PCV?
- Help Final touches before dyno tune
- G37X @ 76,000 miles, Rattling Cat
- X-pipes, Resonators and Muffler (Custom Exhaust Help)
- Mid pipe replacements?
- Help Final piece to the exhaust
- Test Pipe
- Exhaust restriction? 2.5" cats to 2.25" catback
- Top Speed yPipe
- Help Should I remove Stillen splash guard?
- Y-pipe options
- DIY cold air intake
- Help Intake/exhaust combo suggestions
- Tanabe midpipe fitment?
- Help Pulsating hiss from underneath/rear of car
- Help FI RHFC Only For Stock G37xS Coupe
- Catalytic converters
- Looking for pipes for muffler delete on '13 sedan. Are these any good?
- High Pitched Squeal after turning car off
- Help Does MT Fast Intentions CBE fit AT G37
- I need axle back opinions
- Muffler delete vs Manzo
- ISR Y-pipe fitment issue...HELP!
- Cheap eBay Cats?
- Any recommendations for exhaust systems
- Y pipe with 2 3/8in outlet?
- Help p101a MAF
- Motordyne exhaust and art pipe gaskets
- Help Intake size - how big should you really go?
- Muffler delete or ebay axle back?
- Help 370Z Motordyne E370 on G37s Coupe
- Help 350z de exhaust parts to g37 coupe?
- Fitment?
- Cold Air Intake... which is best?
- Help Infiniti G37x Coupe. Should I do a muffler delete?
- Miesterschaft Exhaust
- ISR Y-Pipe does fit Awd
- Searching for AWD coupe exhaust... how is this hard?
- Help unmarked Test pipes
- any advice for TPs?
- Cat-back exhaust
- Help Noise on cold start (Exhaust?)
- Need help resonated test pipes and resonators
- Help 2012 G37X Sedan Topgunz S/C
- Lowest cost FI RHFC
- Help What type of Y-pipe this is? (with no flex)
- Next step for exhaust set up?
- Muffler/Resonator Delete - o2 sensor spacers?
- Exhaust
- Put K&N Filters on R2C Tubes?
- Exhaust pops
- 2010 g37x sedan header issue
- Downstream o2 Sensor Removal
- Help Replacement Catalytic converters
- AAM Competition RHFC's
- Help Test pipes
- Help Injen CAI Filter Size
- What size resonator on FI CBE?
- Oxygen sensor connector
- Help Circuit Werks Resonated Y Pipe - Will it fit
- Help Motordyne Resonated XYZ Pipe
- Moving on with Mods
- TP to HFC
- Help Megan racing Headers
- How good is the stock exhaust?
- Rookie question about test pipes
