Check engine light after intake installation
Old Jul 15, 2016 | 06:05 PM
Dabram's Avatar
Dabram
Just installed a short air intake and the check engine light is now on and will not turn off. Any advice?
Old Jul 15, 2016 | 06:22 PM
Kris9884's Avatar
Kris9884
Make sure the MAF's are installed correctly. Pull the code at AutoZone and see what it is. If its intake related, have them clear it and you should be good. I recommend resetting your ECU as well, search the steps to do so.
Old Jul 18, 2016 | 12:39 PM
bikezilla's Avatar
bikezilla
What Kris said.
Make sure your MAFS are connected.(and clean)
Get the codes for the CEL
Reset your ECU there are some very good threads on how to do this yourself. Takes 5 mins.
BTW you can get a Wifi or bluetooth OBDII code reader to use with your smart phone for ~25 bucks, and an app to use it for free to $10 bucks. Later on it'll save you the trip and time to a place to read it for you, and it'll help with other things down the road.
Old Jul 18, 2016 | 01:49 PM
Jonesmeister11's Avatar
Jonesmeister11
Did you install the vacuum hoses?
Old Jul 19, 2016 | 10:54 PM
crookncastle's Avatar
crookncastle
did you do the install or was it a shop? if its a shop have them check it out. no one here is able to give you the correct answers to your question since you did not provide detailed info in regards to the check engine light concern. did you pull the codes? check for loose vacuum hoses? we are not clairvoyant.
Brian Londry
20
Apr 17, 2022 11:49 PM
F23jeff
General Tech Questions
Aug 16, 2016 04:48 PM
faizan37x
Intake and Exhaust
18
Apr 30, 2016 03:09 PM
F23jeff
Apr 29, 2016 03:22 PM
geazy37
SouthEast
Apr 26, 2016 12:23 AM
