New Intakes: Could I, Should I, Reset the ECU?
Old Jun 21, 2016 | 02:49 PM
bikezilla's Avatar
bikezilla
Seems like a simple question, but I wanted to get some perspective.
I'll be bolting up a set of SRIs this weekend, and I was wondering if I should perform an ECU reset?
I saw the sticky on how to do it. I'm still a bit uncertain about it.
- Is necessary or will daily driving be sufficient for re calibrating the systems?
- Can I damage or brick the ECU by resetting it or not doing it properly?
- Should I clean the throttle bodies during the install or is that too many changes at once?
- Is it worthwhile spraying the MAF sensor with MAF cleaner, or don't fix what ain't busted?
I've already base-lined my OEM intakes as far as intake temps and all the PIDs the OBD-II track. Got a week's worth of commuting both ways.
Thanks!
Old Jun 21, 2016 | 02:58 PM
Broski28's Avatar
Broski28
Yes reset the ECU.
All you need to do is disconnect the power terminal from the battery.
I swapped back to stock intakes for a day, did not reset it and my car started bogging out and would not accelerate.
Disconnected the battery for 10 seconds, problem solved
Old Jun 27, 2016 | 09:42 PM
PongSanity's Avatar
PongSanity
Yes reset. U can do the pedal reset or disconnect the battery for a few...
Old Jun 27, 2016 | 10:55 PM
4doorfury's Avatar
4doorfury
Maf sensor cleaner is a must. You have the sensors out, clean them. It is a preventive maintenance. Make sure you do it when the sensors are completely cool and make sure they air dry before reinstalling them. I let mine sit out for 30 mins.
Old Jun 28, 2016 | 08:12 AM
ANMVQ's Avatar
ANMVQ
Yes reset the ecu, then take the car for a few (2-3) WOT pulls, and like the above clean the MAF's. I'd actually clean the TB's will you at it also
Old Jun 28, 2016 | 10:10 AM
bikezilla's Avatar
bikezilla
Well, I have reset the ECU, cleaned the MAFs and the throttle bodies.
Resetting was quite easy, nailed it on the first time. In fact cleaning the TBs and MAFs was easy too.
ECU Reset:
Originally Posted by South3rn
For those of us who have never done this before, I have made a minor, but important, change
1. Push start button twice to get - Ignition "ON", count to 3.
2. Depress/Release gas pedal 5 times - hard and fast.
3. Count to 10 (not 7!) and fully depress gas pedal.
4. Count to 12 (SES should be blinking), release gas pedal.
5. Count to 10, depress gas pedal.
6. Count to 10, release gas pedal.
7. Turn off ignition, then start engine. ECU reset is done!
Believe me it doesn't work using the brake pedal no matter how many times you try it or what timing you use!
When you assume. you make an *** out of u and me. LOL!
And just in case someone new to this comes across this discussion: You should NOT use Throttle Body cleaner on your MAFs!
In fact, it is written on the label. One cleaner for your TBs and a entirely different cleaner for your MAFs. They're cheap and easy to find.
And there is a very good DYI for cleaning the TBs and another good DYI for resetting your ECU.
Anyway it all worked out well.
Old Jun 28, 2016 | 07:55 PM
Ape Factory's Avatar
Ape Factory
Your engine bay looks fantastic. Really like the cover with the nickel intakes and black strut bar.
Old Jun 29, 2016 | 01:44 AM
bikezilla's Avatar
bikezilla
Thanks man.
I think I'll start looking into some bolt kits, and maybe braided nylon wire looms.
and, and, and....
Willyr33
ECU Tuning / Dyno Data
Aug 24, 2016 03:46 PM
Mattlorentzoe
Apr 14, 2016 01:54 PM
xnick101
Apr 11, 2016 06:39 PM
SonicVQ
Mar 31, 2016 04:20 PM
