Ses
Old Jun 1, 2016 | 11:24 PM
Louiegee97's Avatar
Louiegee97
Ses
Just installed my Stillen Gen 3 Intakes and after i was finished the "Service Engine Soon" light came on.. What can it be? I put everything back the way it was all sensors and all
Old Jun 1, 2016 | 11:32 PM
Run it by autozone and have them pull the code, and write down the code #. You can then reset the code by disconnecting battery for a few minutes. Code probably won't reappear, but always good to ID the code prior to resetting the ECU.
Old Jun 2, 2016 | 09:16 AM
VenomGT9's Avatar
VenomGT9
Definitely just needs the ecu reset but run the codes anyway.
Every time you disconnect a sensor, especially when it comes to air flow, you'll want to reset so the computer can recognize whatever change you just made.
Old Jun 4, 2016 | 02:22 AM
afar1's Avatar
afar1
For future reference, disconnect the negative battery terminal whenever you mod anything that involves the electronic system, such as installing CAI, bleeding the brakes, upgrading the headlights, cleaning the throttle bodies, etc. You want the ecu to be under anesthesia (unconscious) when you're doing surgery under the hood.
I didn't have any warning lights after installing the Gen 3 CAI.
You can also pick up a Scan Gauge II while at Auto Zone, it displays and clears codes and much more.
Have fun modding!
Old Jun 4, 2016 | 04:50 AM
Landshark's Avatar
Landshark
get an OBDII Bluetooth dongle, and use any number of free apps on your smartphone to read and clear codes. you can also use performance/gauge apps like Torque or Dashcommand with it, too.
Amazon.com: OBD2,Hikeren**Mini Bluetooth OBD2** with POWER SWITCH,OBD-II(V1.5) Automotive Diagnostics Scanner /Portable OBD2 Car Scan Tool for Android ONLY: Electronics Amazon.com: OBD2,Hikeren**Mini Bluetooth OBD2** with POWER SWITCH,OBD-II(V1.5) Automotive Diagnostics Scanner /Portable OBD2 Car Scan Tool for Android ONLY: Electronics
milkcow500
116
Aug 28, 2019 03:44 PM
micafd3s
May 21, 2016 03:25 AM
Thanhchampion
May 10, 2016 06:13 PM
Moe_G37x
May 6, 2016 10:41 AM
Moe_G37x
May 5, 2016 01:27 PM
