rwd 37 sedan SPRINGS on 37x awd
Old Nov 7, 2010 | 08:16 AM
use2vw's Avatar
use2vw
SO...would STOCK rwd 37 sedan springs lower a 37x sedan? I've searched and searched and only found Stock 370z front springs and Stock 37 coupe springs installed on a 37x...anyone tried rwd stock sedan springs? any good results? Live in north east and can't "slam" especially with winter around the corner. Thanks gang...
Old Nov 7, 2010 | 11:41 AM
platinumg35x's Avatar
platinumg35x
i think somebody had done it and said the difference in the front was barely noticeable...which is where the huge gap is
Old Nov 7, 2010 | 01:28 PM
6mtg37s's Avatar
6mtg37s
It should go down a bit
Old Nov 7, 2010 | 11:31 PM
bat6wc's Avatar
bat6wc
not g37, but 08 G35 sedan RWD/AWD swap here. Lowered about .5-.75in. I am very happy with the results.
Old Nov 12, 2010 | 10:30 PM
BKG37X's Avatar
BKG37X
Was there any change in ride/handling? I'm thinking of doing the same, can't have it too low with all the potholes and bumps, but would definitely like a lower ride.
Old Nov 13, 2010 | 12:56 PM
6mtg37s's Avatar
6mtg37s
Thats not a low drop at all. It will look like a stock rwd g37s ride height. Plus it will stiffen up a bit for better handling.
Old Nov 13, 2010 | 02:52 PM
Comatose's Avatar
Comatose
Any pics?
Old Nov 14, 2010 | 12:02 AM
bsowhat1's Avatar
bsowhat1
Was the drop even? No droopy butt? How is the ride on the rwd springs?
Old Nov 17, 2010 | 03:36 AM
harp00n's Avatar
harp00n
w8ing for more info about RWD->AWD springs!!
Old Nov 17, 2010 | 08:17 AM
use2vw's Avatar
use2vw
I've decided to go with Coupe 37S front springs (just acquired) and simply do an upper springmount shave for the rear...someone on here did a complete coupe spring swap and had the saggy bum effect...so I'm only gonna do like a .5in shave on the rears and keep the same oem rear springs. With the Coupe37S front springs should bring it down about 1in. up front and hopefully still have a nice raked look. It'll be a Thanx Giv project...will post pics once complete.
Old Nov 17, 2010 | 09:40 AM
6mtg37s's Avatar
6mtg37s
This might help, coupe s springs on an awd sedan:
https://www.myg37.com/forums/brakes-...37x-sedan.html
Old Nov 18, 2010 | 12:27 PM
use2vw's Avatar
use2vw
Yeah that thread was the inspiration..but I'm gonna do some "actual" measuring before and after...as someone mentioned - fingering is usually left for the drive home, under a table or the movies - normally not tied into suspension...
Also, I'm not gonna use the rear springs so - again I hope to avoid the saggy bum look.
Old Mar 31, 2011 | 01:08 AM
MtlG37x's Avatar
MtlG37x
Thread resurection! Anyone manage to put G37S springs on a G37x??? There's a lot of talk but no pictures
Old Mar 31, 2011 | 02:10 AM
Comatose's Avatar
Comatose
If putting Eibach springs designed for the g35s on the g35x results in the droopy bum effect, im sure you'll see the same using the OEM springs on a 37.
Old Mar 31, 2011 | 06:59 AM
bsowhat1's Avatar
bsowhat1
This was done and resulted in a droopy butt.
