Eibach pro springs worth it?
Old Oct 5, 2010 | 08:49 PM
Dvit's Avatar
Dvit
Im looking at these springs I want to eliminate the pretty severe body roll and get a cleaner no wheel well showing look. Yay or nay?
Old Oct 5, 2010 | 08:56 PM
ScottyBeGood's Avatar
ScottyBeGood
Eibach's are good, but to be on the safe side you may want to go ahead and pick up a rear camber kit as well. I just had mine lowered today and could use rear cambers.
Old Oct 5, 2010 | 08:57 PM
wlmngtn's Avatar
wlmngtn
Are you running aftermarket wheels? and yes, ^ I would suggest a rear camber kit. Although Eibach is a small drop, the back does show camber and you wheels will suffer from it; however, very lightly. Camber kit will fix that problem.
Old Oct 5, 2010 | 08:58 PM
Blackjack's Avatar
Blackjack
^ Agreed. Do it right and get a camber kit. You won't be too out spec but you'll be glad you did it after about 15k and you need new tires already.
Old Oct 8, 2010 | 12:30 PM
Dvit's Avatar
Dvit
yea i have enkei rp03 rims same demetions as stock though... just switched to 255s on the rear... ok how much is the camber kit?
Old Oct 8, 2010 | 12:32 PM
Dvit's Avatar
Dvit
like this? Infiniti G37 Eibach Front & Rear Camber Kit (08-up)
Old Oct 8, 2010 | 12:34 PM
ScottyBeGood
Originally Posted by Dvit
^^ Bingo... that's a good price...
Old Oct 8, 2010 | 12:43 PM
Dvit's Avatar
Dvit
seems kinda sketchy to get front and rear for 155 bucks...
Old Oct 8, 2010 | 12:44 PM
Dvit's Avatar
Dvit
and how much was it for the labor to do the springs cambers and alignment.
Old Oct 8, 2010 | 12:47 PM
MOB's Avatar
MOB
dayyum....that's a great price. My Eibach PK just arrived this week for my '09S sedan and I'm debating the camber kit. I think what I've heard is that the rear is the one to watch and the front is unnecessary. Can anyone confirm that to be accurate?
Old Oct 8, 2010 | 12:53 PM
ScottyBeGood
It is the rear that you have to watch... My rear came out to -2.5, where I need to get a camber kit to correct it. Since I am throwing on snow tires here in about 2 months and going to new tires in the Spring, I have sometime to add and fix the problem. But yes, it is the rear.
Old Oct 8, 2010 | 01:01 PM
ScottyBeGood
btw, I was at a -2.3 left and a -2.1 right before the install, which that was from the factory setting. I don't know if all settings come this negative or not but a camber kit will certainly help correct the negative settings.
Old Oct 8, 2010 | 01:55 PM
tyduong's Avatar
tyduong
you have to add the parts to the cart to see that it's 155 for the rear and 350 for the front. still a good price imo. the website says the front camber kit is for a sedan but when i go to eibach's website the part # for coupe and sedan are the same.
Old Oct 8, 2010 | 02:04 PM
A_Palaroan's Avatar
A_Palaroan
i have the coupe and got the eibach pro kits with 20x9.5and 20x10.5 and when i got it aligned the guy got my rears back to spec and my front is off by.02 which he said is nothing.
Old Oct 8, 2010 | 02:24 PM
csnpsu's Avatar
csnpsu
Yea, you really want to pay more, hahahaha
