Going for a drop...need information/person insights
Old Oct 10, 2010 | 05:37 PM
Retromoe's Avatar
Retromoe
Currently im on stock 19 inch sport wheels, I'm planning on buying Eibach pro-kit springs & SPC Rear camber kit. I just need to know if i will need anything more after i drop it, alignment? spacers? is a front camber kit needed? i do not want my rear end tucked in & sitting lower than my front.
Just looking for a subtle drop & since i live in NYC the roads aren't really always good, could the eibach suspension put up with the stress? should i expect any rubbing issues?
Old Oct 10, 2010 | 07:13 PM
TVPostSound's Avatar
TVPostSound
Yes
Yes
Yes
Spacers on stock wheels? 20mm no rubbing with Eibach.
Old Oct 10, 2010 | 08:51 PM
jarena2104's Avatar
jarena2104
Do it right get coilover...
And call kinetix and get there package for front and rear camber and toe bolts
Old Oct 10, 2010 | 08:57 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Get coilovers. You and your car will be happier. It is more expensive but much better in the end
Old Oct 11, 2010 | 09:18 PM
beerme986's Avatar
beerme986
+1 for coilovers. have the eibachs and there ok.
yes for spacers and alignments. camber kit is debatable, boils down to how good of an alignment shop you go to.
Old Oct 11, 2010 | 09:38 PM
Retromoe's Avatar
Retromoe
Yes
Yes
Yes
Thank you, 20MM all around?
In the long run, ill decide to pull the trigger on coilovers, springs will just be a temporary thing until mid spring or summer.
Yes, i rather get coils but for now ill try the eibachs.
Thanks, keep the inputs coming in.
Old Oct 12, 2010 | 10:23 AM
ucla bruin's Avatar
ucla bruin
Yes, you'll need an alignment after a week or 2. But you don't have to have camber kit. Many Eibach owners don't have camber kits, including me. Alignment shop should be able to dial it back to within spec. Get the camber kit if you want to maintain a more factory like setup/camber.
__________________
bkouba88
16
Aug 21, 2015 12:44 AM
SS2006
Aug 11, 2015 10:24 PM
