Need help before tomorrow morning
Old Oct 24, 2010 | 04:46 PM
jarena2104's Avatar
jarena2104
ok here goes, i finally got the car out of the body shop..... such a long time. anyway its all ready to get the bc coilovers and kinetix camber caster and A arms in. i got the 20" vossen cv1's going on with 245/35/20 up front and 285/30/20 in the rears goin on.
now just out of curiosity does anyone know know what would be the ideal and nicest height to have this suspension set to? any thing i should tell him as a heads up to make install easier? any help from anyone already lowered let me know please thank you!
Old Oct 24, 2010 | 05:44 PM
4drScreamer's Avatar
4drScreamer
Don't know about the setting height, but definitely post pics when you're complete. This is almost exactly the same set up that I am looking at for my MW sedan. Also let me know what size spacers you end up with.
Somebody post up what the best height setting is.
Old Oct 24, 2010 | 05:59 PM
amg35's Avatar
amg35
I believe the ideal height would be what you like the look of best. That is the cool thing about coilovers, you can dial in the look that you like.
Sounds like an awesome combo, it's the wheel/tire package that I am ordering.
Please post pics when complete. Thanks.
Old Oct 24, 2010 | 06:25 PM
beerme986's Avatar
beerme986
ideal height would be zero wheel gap but thats not always practical. just know if you keep messing with the height after alignment, you will also be messing with the camber settings
Old Oct 24, 2010 | 06:29 PM
Make sure you're high enough in the rear so those wide tires don't rub. Probably about 26.5" or maybe higher depending on your rear camber setting and type of tires.
Old Oct 24, 2010 | 09:02 PM
amg35's Avatar
amg35
Black Betty, do you think 285 is too much tire for the sedan? Thanks.
Old Oct 24, 2010 | 10:01 PM
I don't know much about the sedan. I have 285 on a 10.5" wheel in the rear. I have the bracket trimmed and I rub a little on big dips on the passenger side. I'm at 26.5" ride height and - 1.6 camber if the helps any.
Old Oct 24, 2010 | 10:14 PM
amg35's Avatar
amg35
Thanks. I fear that 285 may be too much tire for my sedan. I'll have to wait for the pics and experience of the o.p.
If 285 is too much tire for the sedan, I may have to consider a new wheel. From the pictures I have seen, any less than a 285 on the 10.5" Vossen CV1 and the wheel sticks out past the tire.
Thanks again.
Old Oct 24, 2010 | 10:17 PM
jarena2104's Avatar
jarena2104
ya see i never lowered a car before my mechanic is doing all the work, i went with a 285 because i have awd and thats what dials out to be as close as possible with the stock setup rotational wise. and i have a complete camber caster setup front and rear with A arms and toe arms..... so adjustability is going to be second to none. also putting on the complete gt spec under braces as well as strut bars to boot! just kinda want there to be minimal wheel gap. i was looking for a tech write up on lowering a sedan but couldnt find anything. idk if anyone knows a link.
whats the stock ride height does anyone know on AWD sedan? ive been looking at this coil over setup and read the directions and i cant figure out how you get it to adjust and keep it perfect match all around. i noticed that the eibach springs drop lower in the rear than they do in the front.... so im concerned about dropping it uniform all around.
Old Oct 24, 2010 | 10:18 PM
jarena2104's Avatar
jarena2104
oh btw black betty pm me i need your address to send money order for the grounding kit please
Old Oct 24, 2010 | 10:20 PM
jarena2104's Avatar
jarena2104
im not sure ill even end up with spacers i did a test fit and the wheels seemed dead on even....and the rear actually looked like it was poking out past the fender so im sure spacers wont even be an issue
Old Oct 24, 2010 | 10:24 PM
amg35's Avatar
amg35
That is why I initially wanted the 285, because of its closeness to the OEM spec. After seeing pics of a 10.5 wheel on smaller tires, I wanted the 285 because I don't want the wheel bulging out of the tires.
Please post pics and your impressions after the install.
Thanks.
Old Oct 24, 2010 | 10:49 PM
jarena2104's Avatar
jarena2104
ya i should have pics up either late tomorrow or tuesday morning. but i def hear you about the wheel poke issue. i didnt want to have it like that black coupe had it in the vossen shoot. i think it will come together pretty nicely. does anone have any suggestions on dampening settings 1-30 30 being softest ....
Old Oct 24, 2010 | 10:57 PM
Weiboy718's Avatar
Weiboy718
wait a min! you can't run staggered setup on AWD car's.
Old Oct 25, 2010 | 07:54 AM
jarena2104's Avatar
jarena2104
LMFAO! why cant i? your awd system doesnt know how wide your tires are..... its been done plenty of times.
