6 piston caliper vs 4 piston caliper in the front
Old Apr 28, 2011 | 02:08 PM
TeRRoRiFiC35's Avatar
TeRRoRiFiC35
For daily driving use only, is there any real BIG benefit to going to 6 piston besides bling factor? Right now I'm debating going with a 4 piston caliper in the front and rear.
Old Apr 28, 2011 | 02:09 PM
Kidcane's Avatar
Kidcane
Florida G Club
Im gonna guess and say they are about 50% better.
Old Apr 28, 2011 | 02:14 PM
Steveo47's Avatar
Steveo47
If you wanna do 6 put it in the front. Since that's where most of yhe braking takes place. IMO you'll be find with 4 in the front, but no need for 4 in the back. Maybe just 2?
Old Apr 28, 2011 | 02:15 PM
GraphiteG37S's Avatar
GraphiteG37S
What brand are you thinking about? I've heard good things about AP Racing but they're a pretty penny!
Old Apr 28, 2011 | 02:17 PM
WPPJR30's Avatar
WPPJR30
You'll feel a difference, but it's not absolutely necessary. If it was, Infiniti would have given you six in the front to begin with... The stock sport brakes are four piston fronts and two piston rears.
Old Apr 28, 2011 | 02:25 PM
TeRRoRiFiC35
i was looking at either AP or Rotora
Old Apr 28, 2011 | 02:29 PM
Weiboy718's Avatar
Weiboy718
I have the AP racing 6/4 piston two piece rotor kit. The best brake upgrade I ever had. The stock brakes are in no comparison to those
Old Apr 28, 2011 | 06:54 PM
InspiredMan's Avatar
InspiredMan
not really needed for daily driving. Try upgrading lines, pads and even tires for better braking performance.
AP > Rotora is a big difference in price isn't it?
Old Apr 28, 2011 | 08:22 PM
1NEETO's Avatar
1NEETO
For daily driving and even for some track use the stock akebonos are good enough.
Bur the short answer is yes, 6 is much better than 4.
Old Apr 28, 2011 | 08:26 PM
da mayor's Avatar
da mayor
you can also upgrade the brake lines and fluid in your akebonos first if you want to
Old Apr 28, 2011 | 08:28 PM
Viper62382's Avatar
Viper62382
Upgrade to steel braided lines, and dba 5000 series rotors and youll be fine
Old Apr 29, 2011 | 07:13 AM
soundmike's Avatar
soundmike
For daily driving? It won't make much of a difference unless your definition of daily driving means hitting the brakes constantly from high speeds.
I'd go with the suggestions from these guys in terms of doing the lines/pads/fluid first and see if that gives you better stopping power. You could also change out you tires. Your brakes are only as good as your tires ability to stick.
If you do go with 2 more pistons, do your homework and make sure you don't unecessarily shif the bias forward.
FWIW, the G's seem to apply more bias to the rear to begin with.
dwhit757
Oct 12, 2015 04:27 AM
willstophe
14
Sep 14, 2015 09:02 AM
meme405
Aug 19, 2015 07:45 PM
TheLocNar
Aug 16, 2015 07:14 PM
connoisseurr
Aug 16, 2015 04:26 PM
