I thought the drop was small enough where you do not need a alingment???I'm getting mine done on Friday with some 20MM spacers
No, anytime you adjust your suspension, you want to get an alignment. With the eibachs though, the drop is subtle enough that you don't need a camber kit.
Only if you you want your wheels to sit flush with the fenders... People usually go with 20mm. That gives your wheels a nice stance, and there wont be any rubbing.
i just got a question i just got a 2011 g37 and i was thinking of lowering it. Are you sure that lowering it would not void warranty? and which springs would you recommend?
