Upgrading to akebono BBK
Old Sep 18, 2021 | 10:53 PM
AQCE's Avatar
AQCE
My question is I've got aftermarket rims 19s SAVINI WHEELSSize: 19x8.5(+2 Diameter) Offset: +45mm
will the Akebono fit good with my aftermarket rims or will I need to get spacers.
Old Sep 19, 2021 | 06:37 PM
ezbme's Avatar
ezbme
I would imagine that you would be fine. The G35 19x9 with 30mm work, I would expect that yours would as well.
Old Sep 21, 2021 | 09:17 AM
projectpanda13's Avatar
projectpanda13
Caliper clearance with wheels can vary from company to company despite having the same specs.
example:
Enkei RPF1 18x9.5 +38 won't clear Akebono
Gramlights 57CR 18x9.5 +38 will clear the calipers
only way would be to test fit it or try to find on the manufacture's website for clearance information. or reference other cars with large calipers and check clearance
Old Sep 21, 2021 | 09:32 AM
Sometimes it's not the wheel clearance that you have to be concerned about, but the valve stem clearance if your wheel has a deep inner lip.
Unless someone with the same make/model wheels with the same specs chimes in with a solid answer, moving forward can be a leap of faith.
My front wheels are 19x8.5 +32 and the only way to get clearance was to use an aftermarket valve stem adapter, and then a 3mm spacer for peace of mind. It's tight.
Old Sep 22, 2021 | 06:00 AM
The Pope's Avatar
The Pope
@AQCE is there anyone else in your local area that already has the Akebono BBK on their car?
If so, see if they will let you mount one of your wheels on their car.
That way you would know what it would actually look like.
Old Sep 22, 2021 | 10:40 PM
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
The spoke design can often be an issue as well.
Use these templates to measure the rims
https://conceptzperformance.com/imag...artemplate.pdf
https://conceptzperformance.com/imag...nttemplate.pdf
eskalaid
Jul 22, 2016 08:18 PM
IntricateDetail
Apr 25, 2015 12:16 AM
Mik3G37S
Mar 22, 2015 02:07 AM
redrover23
Jul 15, 2012 02:23 AM
ipitythefoo
Southern California
Jun 18, 2010 04:09 AM
