What is this behind my dash?
Old Sep 12, 2021 | 05:44 PM
Carter Ayers's Avatar
Carter Ayers
I pulled some sort of radiator out of my center console along with the AC vent box and heater it has coolant lines attached to it and I have literally so clue what it is please help lol
Here is what it looks like
This is where is was located behind where the stereo used to be
Old Sep 12, 2021 | 06:30 PM
ILM-NC G37S's Avatar
ILM-NC G37S
That is the heater core and that is exactly what it is: a "mini" radiator. Hot coolant from the engine circulates through and as air from the blower passes through the fins, you get warm air.
That unit is completely shot.
Old Sep 12, 2021 | 07:17 PM
Carter Ayers
so I’m building this car as a drift build do I need to replace this unit since I no longer need ac or heat or can I simply complete the loop with coolant lines
Old Sep 12, 2021 | 07:55 PM
ILM-NC G37S
You can just loop it from the engine side of the firewall. There is also a plastic hose coupling that goes from the engine to the firewall that I would either eliminate or replace with a metal one. This coupling has a long history of failure.
Old Sep 26, 2021 | 05:38 AM
Gillan's Avatar
Gillan
Honestly, I would just replace it. Less time consuming and your ********* won't freeze up while drifting in the winter time.
Old Sep 27, 2021 | 10:10 AM
BULL's Avatar
BULL
Moderador
Hi Carter, as stated before that is your HEATER core.
I don't mean this in any disrespectful way however based off on the picture an my years of junkyard experience it looks like you went in with a NOTHING WILL STOP ME mentality since it's a drift car.
It also makes me question your knowledge a bit since Heater cores have been standard in vehicles for probably longer than you and I have been alive and for the most part ALL look similar.
I say this because, electronically these cars can be challenging and for the most part like to challenge the NOTHING WILL STOP ME mentality.
Good luck!
red g37s
Picture Share G Coupe
25
Feb 23, 2012 03:27 PM
kame_sanjo
Jul 28, 2009 01:23 AM
last lemming
Jan 24, 2009 04:38 PM
shabbo
Apr 13, 2008 02:09 AM
