Do I need an exhaust/test pipes for power?
Old Aug 8, 2021 | 10:21 PM
Swang's Avatar
Swang
Just wondering if It’s worth getting intake + ecutek tune?
I don’t want to get an exhaust and test pipes because they make the car loud - and that’s something I can’t have.
Alternative - are there any test pipe systems that do not make the car too loud, smell, and are reliable?
Old Aug 8, 2021 | 11:03 PM
fillup's Avatar
fillup
By definition, a test pipe is literally a straight pipe replacing the cat. Some have resonators, some don't. If you want some middle ground, look into high flow cats.
Old Aug 9, 2021 | 02:21 PM
Swang's Avatar
Swang
What are the horsepower increase on high flow cats and can it be used on a stock exhaust?
thanks
Old Aug 9, 2021 | 02:45 PM
thanks
It doesn't entirely work like that. You might see gains near the top of the curve, and a loss down low. Manufacturers love to give you numbers, right or wrong. In that context, 10hp seems a fair answer.
The best answer is a vague one... match a pair of high-flow cats to your OEM catback and you will experience a noticeable bit of extra grunt, but not a lot. And you will hear a noticeable bit of extra noise, but not a lot.
And yes, you can run high-flow cats with the stock exhaust.
Old Aug 9, 2021 | 03:46 PM
2.2Lude's Avatar
2.2Lude
Here is a blog post by Seb that you might like:SZ ECUTek Tuned Nismo 370Z |
You can see what kind of results to expect with just an intake and tune. IIRC the Z exhaust is a little bigger but your results power wise should be fairly close.
If you are already worried about the sound then IMO leave your exhaust alone.
Old Aug 9, 2021 | 04:06 PM
spoolin03's Avatar
spoolin03
In fact, exhaust (INCLUDING TEST PIPES/ HIGH FLOW CATS/ LONG TUBE HEADERS) is REQUIRED in order to make power on this bad little focka.
My personal opinion, don't even worry about sound. If it's power that you're after, it doesn't matter what others hear as long as you're hauling *** the way you want to.
The only sound I can't live with is drone. That sound literally shakes the matter in your brain loose.
Scruffmcbuff
Intake and Exhaust
Jan 8, 2016 09:47 PM
jamesshifflett
Apr 29, 2013 11:55 AM
marcopolo15
MODDING 411
30
Sep 27, 2012 07:18 PM
SkyzDaL1m1T
Intake and Exhaust
14
Sep 3, 2009 10:59 PM
ipg37
Exhausts
Jan 25, 2009 04:20 AM
