Rims
Old Aug 28, 2020 | 02:50 PM
Junior Castillo's Avatar
Junior Castillo
Rims
Hey guys I知 new to this I知 looking at rims they are 19x85 and the lug pattern is 5x112 I知 wondering if they fit my sedan before I buy them can someone please let me know if they will fit??
Old Aug 28, 2020 | 02:55 PM
Nope. Google "G37 Bolt Pattern".
Create better thread titles.
Welcome to the forum.
Old Aug 28, 2020 | 02:58 PM
Junior Castillo
They guy said I can get adapters but idk if that will make my car feel differnt or cause problems down the road..
Old Aug 28, 2020 | 03:43 PM
Yep, that's a thing. Nothing wrong with spacer adapters when mounted properly. As long as you can manage the poke.
Old Aug 28, 2020 | 03:49 PM
BoomerSpeed01's Avatar
BoomerSpeed01
Could cause problems down the road because if the adapters aren't SUPER thick, you'd have to trim down your factory lug bolts so the wheels sit flush on the adapters.
Old Aug 28, 2020 | 06:44 PM
Most wheels have space between the holes, making that a non-issue. I use 15mm spacer adapters in the winter, and the OEM bolts are more like 25mm long, which is the problem you're describing. But there's space between the holes of my winter wheels, which supports the length of the bolts. And if you use open, flat-top lug nuts, even better.
Here, I've got a pic for that. Love this photo, not sure why... macro shots are cool. Anyway, I use these for about 5 months every winter.
Old Aug 29, 2020 | 01:29 AM
stealthee's Avatar
stealthee
I'd just buy wheels that have the right bolt pattern. There are probably thousands of wheels with the correct bolt pattern because it is so common. Buying the wrong wheels, just to have to buy adapters would be like buying tires and wheels that are too big then having to lift the car like a 4x4 truck.
General Grim
Nov 2, 2019 12:54 PM
NightInSeoul
Jan 22, 2014 08:40 PM
brianxly
Jul 3, 2013 08:32 PM
tonyhwang
Oct 28, 2009 05:31 AM
richyung
Jun 4, 2008 04:24 PM
