Help cancel seat synchronization
Old Oct 13, 2020 | 05:09 PM
Seat adjust man's Avatar
Seat adjust man
I think the motor on my seat is done because it makes a bad noise and doesn’t move when I turn on and open door, don’t see comfort settings when I go to settings. I turned on acc held the set until they blinked once, started engine turned it off opened the door and it still made the noise. Any suggestions or help would be appreciated
Old Oct 14, 2020 | 12:16 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Well, a couple things. First, It sounds like you've got the dreaded broken plastic gear issue, a failure of the drive gear which is supposed to move the seat. (You can find threads on this subject in this forum). Second, you either have a seat memory position that the seat is trying to reach, or you have the Entry/Exit function trying to operating.
Entry/Exit moves the steering wheel up and the seat back every time shut off the car and open the driver's seat. Then it attempts to get both items back into driving position once you get back into the car and start the engine.
From a 2013 G owner's manual:
Cancel or activate entry/exit function:
The selector lever must be in the P (Park) position with the ignition switch in the OFF position.
The entry/exit function can be activated or canceled by pressing and holding the SET switch for more than 10 seconds.
The indicator lights on the memory switches (1 and 2) will blink once when the function is canceled, and the indicator lights will blink twice when the function is activated.
That "SET switch" is the one on the driver's arm rest. Maybe that will stop the sad sound.
Old Oct 14, 2020 | 11:35 AM
Seat adjust man
Life Saver
You’re a life saver. Anyone who needs this in the future make sure the car is off when you hold the set button NOT on acc
obg376mt
Mar 7, 2016 11:40 PM
kelvin21
May 30, 2014 10:13 PM
2010g-ride
Oct 14, 2013 12:15 PM
g37brad
Dec 6, 2012 05:12 PM
