Help 12v/cigg power and climate controls
Old Jul 17, 2021 | 06:49 PM
AnotherVQ's Avatar
AnotherVQ
I have a Qi charger connected to the cigg lighter. When the phone is not clipped/Qi charging the climate controls are non-responsive (but lights are on where applicable). I tried turning the car off and on and the issue persists. I unplugged the charger from the socket and restarted the car and now the climate controls work. I plugged it back in, and they stopped working. Once again when I put the phone on the charger, they work again.
Old Jul 17, 2021 | 07:12 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Now that is a new one.
How close is the charging pad in relation to the HVAC panel? The only thing I can think of is that somehow the magnetic field of the Qi is causing some type of interference with the CANBUS signals.
I know the Nissan OEM charging kits have the pad toward the rear of the center console... perhaps for that same reason..?
Old Jul 17, 2021 | 07:13 PM
AnotherVQ's Avatar
AnotherVQ
Yeah I couldn't find anything online about this.
It's in front of the passenger climate pot.
Old Jul 17, 2021 | 07:21 PM
iCrap's Avatar
iCrap
This is highly unlikely. i have had a Qi pad mounted right next to my radio for probably 4 years now. It's also right in front of my radio panel.
maybe if its a really low quality qi charger? But I have tried 2 of them with no issues. (i just recently updated to a faster one)
Old Jul 17, 2021 | 07:22 PM
AnotherVQ's Avatar
AnotherVQ
https://www.scosche.com/magicgrip-wi...uto-grip-mount
Old Jul 17, 2021 | 07:27 PM
iCrap's Avatar
iCrap
Did you try another cig port and see if that makes any difference? I use the one in the arm rest. I doubt this will make a difference, but worth a try.
Old Jul 17, 2021 | 07:28 PM
AnotherVQ's Avatar
AnotherVQ
I was thinking of doing that but haven't gotten around to it yet and it slipped my mind before I ended up making this post.
Old Jul 18, 2021 | 12:58 PM
AnotherVQ's Avatar
AnotherVQ
My steering wheel volume and other audio controls also don't work under the same conditions.
Old Jul 18, 2021 | 02:31 PM
iCrap's Avatar
iCrap
Makes sense, those don't use CAN, they are going into a plug on the back of the AV unit.
Did you try the other port? if if the result is the same I'd say you have a low quality charger and it's somehow interfering with the AV unit.
Old Jul 18, 2021 | 02:45 PM
AnotherVQ's Avatar
AnotherVQ
Not yet. Been at an event.
Old Jul 18, 2021 | 09:10 PM
SonicVQ's Avatar
SonicVQ
Does the device have an FCC ID number?
If it doesn't, then I suspect the electrical noise emitted by the charging pad is causing the HVAC/radio to stop responding.
Old Jul 18, 2021 | 09:29 PM
iCrap's Avatar
iCrap
I had that thought as well, but it looks like it actually does
Old Jul 18, 2021 | 10:41 PM
SonicVQ's Avatar
SonicVQ
Since it has an FCC ID (IKQMGQ) I guess then it is a weakness of the car, as it wouldn't be designed to block the 110-147 KHz pulses.
Old Jul 18, 2021 | 11:52 PM
iCrap's Avatar
iCrap
Yeah, but the interesting thing is i have a Qi charger mounted right next to my radio panel and I have never seen such issues.
Old Jul 19, 2021 | 08:56 AM
SonicVQ's Avatar
SonicVQ
Weird... I have no idea why.
