Help those will Stillen sways...what's your setting?
Old Jun 20, 2012 | 12:43 AM
sniper27's Avatar
sniper27
For the rear? There's only 2 holes, soft or hard. What is your experience with each? what do you recommend with stock non sport suspension and OEM 19s?
Thanks.
Old Jun 20, 2012 | 02:58 AM
dal1307's Avatar
dal1307
Thanks.
There are only 2 holes but that gives you 3 settings:
Both sides in the soft holes
One side in the soft hole the other side in the stiff hole
Both sides in the stiff hole
My rear is set to the softest setting and the front is set to one hole above the softest setting. With my Tein SSPs this yields a nice neutral setup. I can get the tail out with the gas pedal if desired but it is easy to reel it back in. It took me a few test drives to dial in my Damping and sways to get a setup that I liked. I would recommend that you experiment until you get it dialed in to our taste. Stiffer in front increases understeer (decreases ovrsteer). Stiffer in the back increases oversteer (decreases understeer).
Here is a suspension setup quick reference:
Old Jun 20, 2012 | 09:27 AM
sniper27's Avatar
sniper27
There's only 1 hole in the front.
j50ny
Jul 21, 2017 10:46 AM
kavcheung
Jan 22, 2016 02:40 PM
OneSickBlackG
Jan 6, 2016 08:49 AM
Clutch34
Sep 14, 2015 03:26 PM
jfisher
Sep 13, 2015 07:58 AM
