Tanabe rears with Eibach fronts?
Currently on a set of tanabe nf210 springs. I like the rear ride height but would like to go lower in the front. Has anyone run Eibach pro kit springs on the front and tanabes on the rear? Any pics?
Anyone know if I will have any issues with the different spring rates with the mixed set? If this will work I can also avoid having to get the rear camber arms.
Thanks
Jim
Thanks
Jim
its generally not a good idea to mix spring rates on a suspension. if you like the rear height put some poly bushings on the rear springs and it should keep the rear from sagging down like alot of eibach setups ive seen.
