Eiibach Prokit + Spacers?
With the Eibach prokit for my 2011 g37s will I be able to put on wheel spacers and still use stock camber arms?
Also with a Eibach prokit + Spacer combo, will I be able to fit 295 tires on the back?
Thank you.
Thank you.
you don't need camber kit with the eibach....I had stock with 20MM spacers all around and no rubbing with stock wheels and tires, not even close and sits very flush but you can even go with 25MM on the front. Eibach is a very mild drop on the back especially...295 won't fit on stock 19s, well anything is possible but it will not look right, the most would be 275 on stock, or get new wheels and then just get the right offset so you won't need spacers...currently I have 285/30/20 on 20x10 +20 and slight rub will have to shave the bracket...
Kojack
Oct 9, 2015 05:53 PM
nbast
Sep 14, 2015 12:39 PM
