I want to lower my '12 G37XS.. help and suggestions please!
Old Jul 19, 2012 | 08:01 AM
lopez13jesus's Avatar
lopez13jesus
Hi, Im wanting to lower my 2012 G37XS, im new to all this lowering stuff and dont really know what to go for. If you guys could help me out on letting me know what would be the best way to do this. Im thinking about putting some 20's on my car. What would be the best drop to do with these size rims. I would really appreciate your help!
Old Jul 19, 2012 | 08:20 AM
rks's Avatar
rks
I would suggest looking/searching through the Suspension sub-forum. There are many options for wheels and more than a few for lowering. You will end up between springs or coilovers and depending on how low you may need camber kits.
Your question is very general and it depends on your budget and your goal.
Old Jul 19, 2012 | 08:45 AM
Like rks mentioned, your question could be covered too many ways. If you're wanting a mild drop w/ a smaller budget then Swift springs seem to work well on the X models. The drop is mild so camber kits may not be req'd, this will save you about $550.
If you want the best drop then coilovers FTW, but will set you back a couple grand plus your camber arm/toe bolt sets.
Don't forget to add the cost of a new alignment too
Old Jul 19, 2012 | 10:04 AM
Vini's Avatar
Vini
If you want to go the simple way I would recommend Eibach springs they will lower you ride about and inch and will look real nice with 20... That is the set up I'm currently running on my RWD sedan. Ride is same or better than stock IMO.
Old Jul 19, 2012 | 10:39 AM
jepva's Avatar
jepva
The Eibachs sag in the rear on the X sedan and it looks like crap. Swift is the only way to go for an X sedan unless you go for coilovers.
Old Jul 19, 2012 | 10:58 AM
mystikal's Avatar
mystikal
https://www.myg37.com/forums/wheels-...t-tires-7.html
my car is in there...I have a X sedan with Eibach pro springs...I'm loving it..no chamber thus far...and im running 20" look at my specs.
Old Jul 19, 2012 | 12:20 PM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
I found this video online, not sure if it will help or not but this guy did it to his and it looks great.
Old Jul 19, 2012 | 01:01 PM
slpr's Avatar
slpr
This might help too.
https://www.myg37.com/forums/brakes-...upe-sedan.html
Old Jul 19, 2012 | 05:27 PM
lopez13jesus
Thanks all for your help!
Old Jul 19, 2012 | 05:55 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
What wheels are those in the video? Look like M56 22's?
Old Jul 20, 2012 | 12:11 PM
Igorsky's Avatar
Igorsky
The wheels in that vid look awesome especially after the drop
Old Jul 20, 2012 | 04:25 PM
xSSv's Avatar
xSSv
I've had both springs and coilovers on my xS.
Eibach was good and the drop was even, I've heard good things about swift as well. For coilovers I went with D2 and am pretty happy with them. No noise at all... I originally purchased BC but was extremely unhappy with their customer service before I even installed them.
I would search the suspension section and do your research before pulling the trigger.
Best of luck
PearlPereZ
Jun 21, 2016 06:35 PM
cconklin2
Jan 9, 2016 07:21 PM
phamous
Picture Share G Coupe
Sep 30, 2015 02:15 PM
jfisher
Sep 9, 2015 04:17 PM
ZachThomas
Sep 3, 2015 01:40 PM
