Is this the best Akebono BBK deal?
Old Aug 28, 2012 | 04:40 PM
Seems pretty damn good especially the free shipping and the Nissan calipers (they always seem to cost more than the Infiniti caliper, not sure why). If there's a better deal do tell
Or PM me please. Thanks!
Nissan Akebono BBK Big Brake Kit Complete Upgrade - Nissan 350Z 370Z
Old Aug 28, 2012 | 05:09 PM
Rad_Slinger's Avatar
Rad_Slinger
that says it's for all four calipers.
looks like a good deal to me. comes with everything you need and says 4 piston fronts with 2 piston rears.
other bbk's are way more expensive than that setup.
Old Aug 28, 2012 | 07:49 PM
bluedevils95's Avatar
bluedevils95
Looks good to me. You going to jump on this?
Old Aug 28, 2012 | 08:10 PM
JohnnysG's Avatar
JohnnysG
I'm pretty sure CZP... a vendor on this forum sells the BBK for 1.2k
Old Aug 28, 2012 | 11:49 PM
Thanks for the replies guys. CZP has them on their BBK thread for $1425, possibly more if they don't have free shipping. The Nissan calipers I prefer over the Infiniti just because it'll go better w/ my OB G. Now to convince the wife (wish me luck)
Old Aug 29, 2012 | 12:11 AM
Fezzik's Avatar
Fezzik
Check out Tunerzstore as well
Your one stop online shop for the best prices on Nissan, Infiniti, Hyundai Chevrolet, parts: AMSOIL, R2C Intakes, ARK, Invidia, BC Racing, Hotchkis, Tein, Greddy, MBRP Exhaust, Hawk, Project MU, StopTech, Mishimoto, AEM, Injen:Nissan, Infiniti, Chevr
Old Aug 29, 2012 | 10:02 AM
2009G37Bandit's Avatar
2009G37Bandit
That looks cool. Just ordered stop tech drilled and slotted rotors and pads (Posi Quiets) for $560.................Is it worth it for the calipers and other stuff?
I can still return, it's unopened.
Old Aug 29, 2012 | 10:58 AM
For me I'm not really interested in the slotted or slotted/drilled rotors (haven't heard that they really do much for street use, and the drilled rotors are prone to cracking), but the larger S rotors and the better performance and much improved look of the bigger Nissan calipers would cinch the deal as far as going for the $1500 pkg I linked. You're already over a 3rd there and you still have the stock rotor size and generic calipers, I'd take the plunge if I were you.
Unfortunately I can't pull the trigger right away but if I caould these may be worth a look, and it's only be about $500 more than what you've already invested~He's got a "make an offer" listing so you may get it even cheaper
http://www.ebay.com/itm/SLIGHTLY-USE...06%26rk%3D1%26
Old Aug 29, 2012 | 12:25 PM
soundmike's Avatar
soundmike
True and true, IMHO, and i do take it to the track occasionally. The RB 2pc fronts have open slots but would've preferred blanks if it was offered. I ran the OEM 13" sport rotors on the track as well.
Btw, try piecing out the parts and see if you can get it cheaper. That's how i approached it a while back and saved a couple hundred dollars for new parts.
p.s. "Better Performance" is somewhat of a misnomer though. The OEM non-Akebono set-up will do fairly well on good pads and fluid. Plus, you save on a few pounds worth of rotor material/weight over the standard Akebono's.
Old Aug 29, 2012 | 01:49 PM
I'd really like to go w/ a Wilwood setup but just a bit more $$ than I can justify. That Ebay deal looks pretty killer but I just can't get the Mrs. on board soon enough To be honest I'm mainly doing it for looks as I think those gunmetal Nissan calipers would look perfect w/ the rest of my car.
Where did you piece together your setup, probably through several vendors? Appreciate your help, thanks!
Old Aug 29, 2012 | 01:55 PM
soundmike's Avatar
soundmike
Nothing wrong with doing it for looks. I spray-painted mine blue for that reason
For $1k, that's a great deal! Even those in the FS forum here don't usually go that low.
Yep, through various vendors. Most of it was sourced through InfinitiPartsUSA.com. I've got the part #'s if it'll help.
Akebono Big Brake Kit Part Numbers
Old Aug 29, 2012 | 05:23 PM
Thanks a lot for that part list, just priced it all out and it comes in about $1450 without shipping, so when the time comes hopefully that nismo deal will still be going on
Old Sep 1, 2012 | 06:11 AM
Minh7410's Avatar
Minh7410
Do you guys know if those Akebono brake kits will fit on the G37x's?
Old Sep 3, 2012 | 11:32 AM
They will fit but be sure to use this template on your wheels prior to purchase, the Akebono Calipers are huge and won't clear most wheels without spacers.
http://www.conceptzperformance.com/i...nttemplate.pdf
Old Sep 3, 2012 | 05:00 PM
Minh7410's Avatar
Minh7410
Thanks Man!!!
