Swift Springs RWD Sedan
Old Aug 22, 2012 | 06:28 PM
Bota36's Avatar
Bota36
Hey Everyone,
I just got the Swift Springs put on yesterday. They are the prototypes they put on my G and are the result after about 45 days of testing. This is the final product and they will now be available for the RWD Sedan. Leonard at Swift said they will contact all retailers to inform them they are available.
The drop is: 1.2 in the front and .08 in the back. I was told the spring rates are: Front: 6.5kg/mm; Back: 6.3kg/mm.
My review so far: My 1 hour drive home on the freeway was smooth. I'd say just as comfortable as stock but much better handling. The springs seemed to absorb the freeway bumps nicely. On the streets, I hit a few corners pretty hard and got very little roll. The steering was so responsive it took me by surprise. I highly recommend them for those looking to lower their G but not compromise the ride comfort. Because of what I do for a living, these springs are perfect for me. I'm so flippin happy!!! By the way, I plan to get some 19" rims...hopefully soon.
Thanks go out to Zoster33 for all the great input.
Hope this helps.
Before front
After front
Before back
After back
After side
Edit: Now
Now
Attached Thumbnails Swift Springs RWD Sedan-front-before-800x601-.jpg   Swift Springs RWD Sedan-front-after-800x600-.jpg   Swift Springs RWD Sedan-back-before-800x600-.jpg   Swift Springs RWD Sedan-back-after-800x600-.jpg   Swift Springs RWD Sedan-side-after-800x600-.jpg
Old Aug 22, 2012 | 07:48 PM
jasyn's Avatar
jasyn
nice. can't wait to get these. been holding off on remodding my car .. but stock sport suspension isn't cutting it for me and the car needs a drop & sway change at least.
part #?
Old Aug 22, 2012 | 08:10 PM
It's great to see these. But don't the same springs for the Coupe application fit the Sedan? I don't think other spring manufacturers have different part numbers for coupe and sedan, do they?
Old Aug 22, 2012 | 08:23 PM
Bota36's Avatar
Bota36
Hey Black Betty, they previously put the coupe springs on in order to get the specs for the sedan. The coupe springs lowered the front 1.2 but the back 1.3. It was a harsher ride too. They sent the specs to Japan and they then made the RWD sedan springs, which are now on my car. Apparently the weight distribution is different from the coupe to the sedan. I really love look and the ride is awesome too.
Old Aug 22, 2012 | 08:30 PM
Cool. Thanks for the info. Do you have any contact info for anyone at Swift that you can share regarding these? Manufacturer part #? ETA for them to be on the market? Retail price?
Old Aug 22, 2012 | 09:28 PM
Bota36's Avatar
Bota36
Yes, call Leonard at (909) 923-9788. He should be able to get you all the info you need. He's a really cool Guy.
Old Aug 23, 2012 | 12:42 AM
dimsler's Avatar
dimsler
These spring rates seem kinda soft? 6.5kg/mm? thats 350lb, I'm pretty sure sport springs have higher rates.
Old Aug 23, 2012 | 03:17 AM
Bota36's Avatar
Bota36
Hey Dimsler, I was told by Swift they are set up for the sedan to provide performance and comfort. From my driving, it appears they accomplished what they were setting out to do. So far, I'm really liking them.
Old Aug 23, 2012 | 08:33 AM
Looks like the perfect solution for those wanting a mild drop without the need for the camber arms & toe bolt kit. This is the way the G should have come from the factory. Nice info!
Old Aug 23, 2012 | 11:44 AM
Bota36's Avatar
Bota36
Black Betty, I just got an email. Here's the info you requested. Parts no. 4N908, eta is 1.5 months and MSRP is $419 (same as coupe and AWD G but may vary depending on retailer).
I agree blnewt. I still need to get an allignment but don't foresee that i'll be getting the camber kit.
Old Aug 23, 2012 | 11:49 AM
Thanks for sharing the info OP.
Old Sep 7, 2012 | 01:26 PM
DustinEarnhardt's Avatar
DustinEarnhardt
Hey Bota, two weeks in are you still loving them as much as you did originally? Any additional thoughts or insights? How about alignment results?
These are now my #1 top choice for springs based on what I've read so far, but I want to make sure I make an informed decision.
Thanks,
Dustin
Old Sep 7, 2012 | 10:14 PM
2009G37Bandit's Avatar
2009G37Bandit
Got Eibach Springs (Pro-Kit) on their way AND a Camber kit for front and rear, camber kit was twice the price of Just the springs, BUT, I wanted it to be right.
Old Sep 10, 2012 | 03:36 AM
Bota36's Avatar
Bota36
Thanks,
Dustin
Hey Dustin, yeah I'm still lovin them. I take clients around in my G and the ride is pretty smooth. These fit exactly what I was looking for by lowering without getting a harsh ride. I have to give them 2 thumbs up!!!
I still haven't got an allignment because I was going to get new wheels. But I'm not sure when that'll happen so I might just go ahead and get it done.
Old Sep 10, 2012 | 12:03 PM
DustinEarnhardt
Awesome. Glad to hear it. Please post the alignment results if you can when you get them. If they come back with no kit needed, I'm pulling the trigger on these.
