brake cleaner
Old Sep 7, 2012 | 11:12 AM
randy0211's Avatar
randy0211
brake cleaner
I know after removing the stock BBK pads, I am suppose to clean them out.
Would it be problem if the brake fluid go on the caliper?
Old Sep 7, 2012 | 11:39 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Brake fluid is not good for any painted surface.. Wipe off immediately.
How did you get brake fluid with just pad removal??
Old Sep 7, 2012 | 11:44 AM
randy0211's Avatar
randy0211
Thanks, I guess I am gong to tape it up just to be sure
Old Sep 7, 2012 | 07:20 PM
quakerroatmeal's Avatar
quakerroatmeal
Did you mean brake cleaner and not brake fluid? Are you asking if it's ok to clean the calipers with the brake cleaner? Or did you change your brake fluid and it got on your calipers..but like the above said brake fluid is corrosive and should be wiped off any painted service immediately.
Old Sep 7, 2012 | 07:37 PM
randy0211's Avatar
randy0211
Thanks for catching that .....I meant brake cleaner....
Old Sep 7, 2012 | 11:43 PM
quakerroatmeal
Brake cleaner isn't going to harm anything. People actually use it to clean off all the dirt,grime off the caliper/pins/shims. You wouldn't need to tape it up.
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
halfbreedcuban
Sep 27, 2015 08:58 AM
