Brake fluid
Brake fluid
Im looking to upgrade to new rotors and pads + SS lines for my akebonos in the near future, and am looking for advice on brake fluids as I have no experience with anything other than oem. I daily drive my car, often "spirited", and have only tracked it once but another track day is almost inevitable.
Thanks in advance for any help or advice
Different in WHAT way? Explain.
I have SS Brake Lines, StopTech D&S Rotors, and Posi Quiet Pads. I might get some new Brake Fluid since we will need some anyway.
Thanks
Bandit.................
Thanks
Cool, KNOW about the SS Lines (Have a set in ther mail on their way to match my Drilled andf Slotted Rotors and Posi Quiets), just didn't know what difference Brake Fluid really made, Feel Wise..............................
Thanks
Thanks
Bandit, if you're changing the pads, rotors ans putting in SS line..I would highly recommend changing out the brake fluid. You're already having to bleed the brakes because of the SS line install...might as well change the fluid while you're at it.
I suppose it doesn't matter what kind you go with unless you're tracking your G. If you intend on tracking your G, go with a high temp like Motul or amsoil.
Mattimus
10-04-2015 01:33 PM
