No access to damper adjustments rear coilover on top on 2011 G37S sedan??
Old Sep 5, 2012 | 06:46 PM
NissanTech's Avatar
NissanTech
This is for the guys with coil overs suspension with the adjustment ***** being on the top of the rear struts, how do you access the adjustment **** with out removing the rear struts? I've tried removing the trunk liner, can't see a thing, tried removing back seat as well, no luck. Design flaw from Nissan? Any info is appreciated, thanks!
Old Sep 5, 2012 | 08:07 PM
jorwick's Avatar
jorwick
You have to jack your car up depending on how your stance and height is and get your hand in there above the wheel, otherwise take the wheel off.
Or just get this
Old Sep 5, 2012 | 08:10 PM
rks's Avatar
rks
I had no luck here with the same question.
but basically you have to drop the strut unless you get electronic damping or those extensions.
Old Sep 5, 2012 | 09:46 PM
NissanTech's Avatar
NissanTech
I guess i am not alone....
Old Sep 6, 2012 | 03:10 PM
soundmike's Avatar
soundmike
Sedan? If so, you have to drill a hole to access them.
I wouldn't say it's a design flaw since these cars weren't made to have adjustable dampers in the first place.
Old Sep 6, 2012 | 04:48 PM
jorwick's Avatar
jorwick
Why do you need access to them more than once or twice to get things dialed in? If you change your driving enough for different suspension set ups I really suggest edfc or some other electronic option.
Old Sep 6, 2012 | 06:57 PM
Dark Sarcasm's Avatar
Dark Sarcasm
BC BR struts can be adjusted after removing the rear wheels. The adjuster **** is mounted on the side now.
superjoey
31
Mar 22, 2023 11:56 PM
Clutch34
Jun 24, 2022 10:48 AM
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
Ghost90
Aug 5, 2015 11:19 AM
Ricio1991
Aug 3, 2015 10:17 AM
