View Full Version : G37 Coupe
- CSC or master?
- Do all models use the same spring bucket?
- Online parts/diagram
- A/C condenser replacement, R134 Leak
- Nismo V1 Wheels Questions
- G37 Throttle lag
- Pros and Cons of 2012 G37 IPL
- FS 2 10” rockford fosgate subs, fitted box, Phoenix gold amp $350
- How long can these engines last if buying a used high mileage g37?
- O2 Diagnosis
- just muffler delete, not resonator delete
- G37 interior lights and seats not working
- Driver Assistance Button
- Just got a 2010 g37 coupe and was looking to repaint it
- Has anybody ordered this front bumper?
- used 2008 G37S - anything to look out for?
- Panting Interior Trim
- I'm looking for IPL fog light inserts
- P006A, P0101, P0175, others-OBD Fusion Report Attached
- High idle, power loss, please help
- Transmission harsh shifting
- Totaled G37XS coupe Advice
- Trunk Latch Actuator Issue
- Ark exhaust resonator delete
- Should I replace my gallery gasket? Has damage been done?
- Tire Sizes on AWD
- G37 coupe Rear seat fold
- Infiniti G37 issues
- Repair or change car?
- G37x and G37 Rear Sway Bar
- Huge Coolant Leak
- Does the 2011-2013 G37Xs Coupe come with intelligent Cruise Control?
- Brake Pads
- G37 coupe mesh grill - i beg of you!
- G37 Base
- 3 inch intakes
- Input on Q60 Coupe Wheels
- Drl bulb size help
- G37 water leaking under glovebox
- Driver side headlight issue
- Auto windows on door open/close
- Hissing noise on Driver side in the engine bay
- Good Budget Exhaust Note
- Need help with codes
- Lost key fob… Need help
- Into the dash
- Coolant Flush😥
- Who Can Make Me Custom Wire Harness for G37 Paddle Shifters??
- Help With Front Bumper Lip
- Bcm
- Dash illumination
- G37xs coupe production numbers?
- LED steering wheel install issue
- Axle back exhaust on AWD coupe?
- Unexpected fix for front end shudder at speed.
- Help with harness layout numbers
- Akebobo rotor size?
- Weird sound when trying to start the car
- Engine heat in the cabin
- 5AT Coupe ebrake
- Any one else notice a transmission hesitation on hard stop?
- Interior Leak (not the sunroof drain)
- Can you swap a tuned ECU into another G37?
- g37 z1 cold air intake
- G37 Fuel return
- Rear camber/ upper control arm?
- Aftermarket Rear Spoiler options for the Coupe
- looking for IPL fog light inserts
- Remove micro nicks (scratches) from front windshield?
- Car won't pair with iPhone
- Leaking on the right front and rear
- G37 high rpms low speed
- Such a thing as Software Optimization for Engine/Transmission?
- Does anyone know what this button does?
- Wheel weight vs akebono caliper 🤬😢
- Q40 sedan interior parts interchangeable with G37 coupe parts?
- Car Ignition Problems
- Average Price for an Intake and Exhaust?
- Ecu fuse keeps blowing
- Odd tyre set up
- Dare to be different - Engine bay remodel
- Ceramic Tint today!
- Is this normal rust for 100k miles?
- 2010 x coupe smashed Bumper. ID. Options?
- Do 08-13 G37 Coupes and Sedans share the same hood?
- Turbo / Supercharger / boosted PCV Setup?
- Water leak 2013 IPL
- Places to get a driver side window motor for a 09?
- Transmission is not shifting
- Akebono Brake swap
- Auto kits x products
- AT Shifter knob opinions
- Amber Key but no ESCL?
- Failure to start issues
- Chassis brace for our cars
- Black Grille
- Need help finding ISSUE
- Help. Stumble Stutter, no error codes
- Passenger window stuck cracked
- Do you think this will rub? (Air suspension)
