CSC or master?
Old Sep 29, 2021 | 09:56 AM
Ryguy1003's Avatar
Ryguy1003
CSC or master?
Got a 2011 g37 coupe with 102k.
recently changed the clutch and flywheel. But did not replace the csc.
The car ran for a month, and now its down. The clutch pedal now sinks to the floor. Is my csc now bad?
When all of this happened, the clutch fluid leaked somewhere, just don’t know where.
I’m now trying to bench bleed it. But the fluid is going down very slow. What to yall think is going on. Thanks.
Old Sep 29, 2021 | 11:13 AM
BULL's Avatar
BULL
Moderador
Sounds like your pump is done and many times the pump will send the debris to the CSC. This debris apart from common pump wear is due to the terrible black hose that breaks down and kills the pump prematurely.
You'll need a pump for sure, as far as the CSC goes, the more you try to bleed it on a bad pump the higher the chances are that you'll kill it as well.
Old Sep 29, 2021 | 11:36 AM
Ryguy1003's Avatar
Ryguy1003
Thanks! Damn that sucks tbh. What do you mean by pump? Just got some pressure back, and now I can finally see a leak from the bell housing. Im pretty sure now its the CSC
Old Sep 29, 2021 | 11:52 AM
There are a number of aftermarket solutions which address the design flaws in the CSC, because it's almost a given the OEM CSC will fail eventually in the lifetime of the G/Z 6MT, if not more than once.
Typically, replacement of the OEM CSC with a different solution goes hand-in-hand with a clutch/FW project. Clutch MC too, if your CSC is corrupted. It's a shame you didn't come across that first before getting into this, because as you know the process costs more in labor than parts.
Old Sep 29, 2021 | 01:03 PM
RobC7's Avatar
RobC7
^This x100.
Looks like you've identified the problem. When my clutch pedal sunk to the floor, I looked under the car and saw the fluid around the bellhousing as well.
Old Sep 29, 2021 | 01:05 PM
Ryguy1003's Avatar
Ryguy1003
yep was deff being a lil cheap ***, now it crept up on me. Smfh
Ryguy1003's Avatar
Ryguy1003
Would I be able to get around with the csc leaking? Could I top it off everywhere I go?
Old Sep 29, 2021 | 02:01 PM
Nope. Buy the ZSpeed CMAK kit (or something similar), get the car towed to a shop and cry into your beer, man. Sorry.
Old Sep 29, 2021 | 03:05 PM
JSolo's Avatar
JSolo
Just say no!!!!!
With 100K, you really should replace the MC and slave. In fact, I believe the FSM says anytime the slave is removed, it should be replaced.
Old Sep 29, 2021 | 03:09 PM
Ryguy1003's Avatar
Ryguy1003
Just ordered one from z1. I’ve previously changed the MS already about 3 months ago. After this, everything else should be new. Tbh this is all a headache 😂,
Old Sep 29, 2021 | 03:12 PM
JSolo's Avatar
JSolo
Just say no!!!!!
True. The real headache is driving with no clutch. I've never experienced this on a car, but have (to some extent) on a motorcycle. Clutch cable frayed, was down to 2 strands.
Old Sep 30, 2021 | 10:47 AM
BULL's Avatar
BULL
Moderador
You should have started with this
Slave said no more.
Rybitron
Jan 1, 2020 04:40 PM
19
Oct 22, 2018 02:01 PM
Jonesmeister11
22
Dec 23, 2015 02:30 AM
V36Skyline
General Tech Questions
Jun 7, 2012 06:42 AM
Nautic6
Jul 11, 2010 03:00 AM
