Passenger window stuck cracked
Old May 16, 2021 | 08:26 AM
trmoore777's Avatar
trmoore777
Hey everyone I bought a g37s a few weeks ago but the passenger window is stuck cracked open. The window motor has been replaced to no avail. My next thought would be the actuator as the window seems to be stuck in the position it would need to be in for the window to clear the door jam when opened. I have also tried the window reset procedure and that didn’t work. If anyone else has experienced this problem I would appreciate your thoughts thanks!
Old May 16, 2021 | 10:17 AM
ILM-NC G37S's Avatar
ILM-NC G37S
1) Any warning lights on the gauge cluster, for example: "Door Open?"
2) When you open/close the (pass) door, does the window "try" to do anything AND does any warning come up on the cluster?
3) Does the AUTO UP/DOWN function work at all?
Old May 16, 2021 | 11:15 AM
trmoore777's Avatar
trmoore777
1) There are no constant warning lights but when the door is open I do get the usual door open warning.
2) The window hasn’t tried to do anything since I bought it door open or closed
3) The auto function does not work at all for drivers window
4) Thanks for your reply!
Old May 16, 2021 | 11:37 AM
cparise's Avatar
cparise
window glass height adjustment-no more leaks!!! - MyG37
https://www.myg37.com/forums/d-i-y-i...ore-leaks.html
Old May 16, 2021 | 11:54 AM
ILM-NC G37S
So, in other words, the passenger window does not move at all whether using the driver switch or the passenger switch?
Does driver side work as intended?
Old May 16, 2021 | 11:58 AM
trmoore777's Avatar
trmoore777
Yes other than the auto function
Old May 16, 2021 | 12:14 PM
ILM-NC G37S
Is the passenger side getting power? With the key on, does the passenger switch illuminate (will be hard to see in daylight, but...). Does passenger side door lock switch work?
Also, wouldn't hurt to check the harnesses at the BCM (pass side footwell under dash).
At this point, if the passenger window is DEAD, and the driver side only works manually (no auto up or down), then the likely culprit is the driver side master switch.
If you are skilled in the use of a multimeter, you can check voltage and ground connections at each door. Unfortunately, there is not much else that can be diagnosed here.
Old May 16, 2021 | 12:51 PM
trmoore777's Avatar
trmoore777
So I believe the passenger side is getting power (the door lights work). As for the door locks they’re a little squirrelly too as in they’re usually stuck in the unlock position and the switch only works intermittently. I’ll still check the harness mentioned as well as power and ground. Then after I’ll try replacing the master switch. Thanks for your help
Old May 16, 2021 | 01:07 PM
ILM-NC G37S
The door "puddle" light is a completely separate circuit from the window/lock switch. One has absolutely nothing to do with the other...
Being that the LOCK switch doesn't always work, leads me to suspect either a power issue or a problem with the serial com link. Remember, both driver and passenger switches communicate with each other via the BCM.
I would start with the pass door/ switch first. Then check the BCM connectors (and for water), and finally the driver master switch.
Old May 16, 2021 | 01:31 PM
trmoore777's Avatar
trmoore777
Originally Posted by ILM-NC G37S;[url=tel:4295561
4295561[/url]]The door "puddle" light is a completely separate circuit from the window/lock switch. One has absolutely nothing to do with the other...
Thanks for your help I’ll update with progress when the rain stops
Marvel120
Mar 18, 2016 11:41 AM
xxcomnupxx
Aug 25, 2014 05:28 PM
Pieman
May 20, 2014 04:25 PM
PongSanity
Oct 7, 2013 10:52 AM
CrazyBulgarian
Feb 20, 2013 01:53 AM
