PDA
View Full Version : G37 Coupe
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Can’t get my passenger Maf sensor off
  2. Engine Ticking Noise
  3. More Mass Air Flow Sensor questions
  4. Regamasters?
  5. Cylinder 2-4-6 misfire
  6. 2012 Electrical Problem - Headlights/Wipers
  7. Water leak
  8. 7at transmission question
  9. strange grinding noise when starting engine
  10. Moulding Clips
  11. AC not working
  12. Fuel cap loose constantly
  13. Very high idle need help!
  14. Electrical Mystery
  15. Installing fogs on an 08 coupe with a sport bumper.
  16. Z1 Nationals
  17. OEM Trunk Spoiler
  18. How to replace part 80833-JL00A side mirror triangle weather strip
  19. Weird noise
  20. Max tire size
  21. Suede Headliner Replacement
  22. G37 swap from AT to MT
  23. What wheels are those?
  24. Headlight question
  25. Dumping the clutch
  26. G37 Help - P0335 - Limp Mode past 6.5k
  27. Auto Shifter
  28. CEL eliminator
  29. 2010 g37x coolant change
  30. Randomly Shutting Off and Irregular Shifting 08 journey
  31. Another Nismo Exhaust
  32. Cracking Dashboard! Help
  33. 370GT Exhaust
  34. A/C problem
  35. Nav Unit Question
  36. Car feels sluggish after 20 mins of driving
  37. Help with Brake Lines Removal
  38. Repainting 10 year old G37 coupe
  39. Reputable dashboard replacement shop in East coast?
  40. eBay Catalytic Converters
  41. Damaged subframe
  42. Problems After Fueling
  43. Spec-D Headlights
  44. Ultra High Milage g37x
  45. Coolant leaks under the engine
  46. STUCK IN LIMP MODE (codes P0021, P0524, P0448)
  47. Fender
  48. Loud knock when going from park to reverse
  49. G37x aftermarket rim replacement downsize
  50. P0420, P0057 O2 sensor replacement
  51. 2013 g37x coupe door problems
  52. Old Topic but still relevant aka DRL led bulbs
  53. No Crank No Start
  54. 2010 g37 code p1089! SOS
  55. Engine Bay Beeping
  56. Center console completely dead
  57. HELP! Replaced my AC Compressor still warm HELP🙏🏾
  58. Charging system diagnosis
  59. g37 stalled out while driving and now wont crank
  60. Aero Install Advice
  61. Stolen and Recovered. Now what?
  62. Missing Intake Mounts?
  63. Chirping noise rear driver wheel
  64. Infiniti Performance Line, Overview
  65. Slow acceleration issue resolved
  66. G37 Front Passenger window
  67. Parts locate & Sound deadening solution
  68. Can I run rear tein coilovers with the front still being stock?
  69. Trading ARK Catback for Stock Sport Coupe Catback
  70. G37x Coupe Lowering Spring Questions
  71. 2009 G37X Fuel Damper
  72. P010C Error Code
  73. Crank but no start
  74. Limp Mode/ Idle Jumping
  75. Sport package features vs Base
  76. Engine mount bracket
  77. Changed the spark plugs and all fluids, gas mileage dropped 20%
  78. About to get hfc on my g37x with muffler delete
  79. Trunk lid gap help
  80. Would rear camber arms alone be enough for a 1” drop?
  81. Center console is completely dead
  82. Electrical problems help
  83. New Seats for G37
  84. Upper Radiator Hose Leaking
  85. New g37s owner here
  86. Another newbie soon to hop on the G/Q train. But will it be G, or Q?
  87. M35X vs G37x Suspension
  88. Swapping in a VR transmission
  89. Shuts off while driving
  90. Tuning 08 G37S Coupe
  91. New Trans needed 2008 G37S 5 AT
  92. 08 G37 Bogging at traffic light stop
  93. Comfortable Aftermarket Seats
  94. Manual Transmission Rattle -New trans, clutch, flywheel
  95. 2012 g37 coupe Unknown overheating
  96. 2008 G37 hard shudder when shifting from 2nd to 3rd
  97. Booster car seat suggestions
  98. G37 Bushings
  99. 08 G37 no power/ no start
  100. 2008 G37 6MT - RPM rev after cold start
