Fuel Pump Replacement
Old Aug 18, 2022 | 09:23 PM
dedman's Avatar
dedman
Anyone have information on pump(s) part number(s) if I want to replace the fuel pumps in my Q40? (Same as the G37)
I know that it's a saddle tank with two pumps - are they both the same? Getting SES light for resistor issue on the fuel pump and want to replace.
Any links to the products would be appreciated too!
Old Aug 19, 2022 | 08:58 AM
ILM-NC G37S's Avatar
ILM-NC G37S
I think there is a common misconception that these cars have TWO fuel pumps. They do not. They do, however, have TWO fuel (level) sending units- primary and secondary:
That said, for a 2015 Q40:
Fuel Pump p/n: 17040-1NC0C (Fuel Pump- Complete) ≈$350.
This should be a complete unit with the pump AND the primary sending unit and gets mounted in the passenger side of the fuel tank.
Sender Unit (Fuel Level/ Gauge- Secondary) p/n: 25060-1NC0C (Sender Unit- Secondary) ≈$110.
This gets mounted in the driver side of the fuel tank.
Prices as of 19 August 2022 from discountinfinitiparts.com
As always, VERIFY these part numbers against your car's VIN BEFORE you buy!
Old Aug 19, 2022 | 10:51 AM
Selym's Avatar
Selym
Do you have to drop the tank, or is there access under the rear seat?
Old Aug 19, 2022 | 11:12 AM
ILM-NC G37S
Just pull up the rear seat cushion (bottom) and everything is right there. It is best to make sure the tank is at half or less to minimize fuel spill when removing the unit(s).
This also assumes that all of the necessary precautions have been put into place to reduce the risk of explosion, fire, personal injury, etc.
Old Aug 19, 2022 | 04:31 PM
SonicVQ's Avatar
SonicVQ
The description of the code may or may not be the problem.
What is the code?
When it comes to fuel gauge issues it generally boils down to 2 items: the sender or the M&A module.
Old Aug 21, 2022 | 10:48 PM
dedman's Avatar
dedman
Thank you for all of the information! I don't have the code handy, but I know it says that there is low voltage ---- I think on the sending unit. I will try to get the code tomorrow.
Old Aug 23, 2022 | 10:31 PM
dedman's Avatar
dedman
Here's the code:
P0462
Fuel level sensor "A" circuit low
Anyone know which part I might need to replace to fix the issue?
Old Aug 24, 2022 | 08:28 AM
dedman's Avatar
dedman
Thank you for the response - the code is below - also wondering what is the M&A Unit?
Old Aug 24, 2022 | 10:25 AM
BULL's Avatar
BULL
Moderador
One way to test this code is to pull both unit and move the level sensors on your own. If both check out your issue might be elsewere.
Old Sep 4, 2022 | 07:23 PM
dedman's Avatar
dedman
Issue is resolved. Thank you to those who commented especially ILM-NC G37S! He helped me out via PM -- diagnosed the correct problem as the Unified Meter and AC Controller. Replaced this component and the gas gauge is working correctly and Service Engine Soon light is cleared from the dash.
Here are a few links that will help you if you have this issue.
1. Explanation of the issue:
2. Quick video showing how to open up the dash to get to the AMP module, which sits directly on top of the radio:
Old Sep 4, 2022 | 07:26 PM
dedman's Avatar
dedman
One last question - the airbag light is blinking, I know that there is a way to clear this - but I can't find it. Anyone have instructions on getting rid of this - I think that it is on because of the work that I did......
Old Sep 4, 2022 | 07:49 PM
ILM-NC G37S
Usually it clears itself up after a few drive cycles. In the alternative, here is the method to reset the SRS light. You probably had the battery connected while you replaced the amp which will cause the SRS light to flash. Easy reset.
And congratulations on getting the issue resolved!
zinger11
Dec 11, 2023 11:01 AM
Dan08g37s
Oct 26, 2017 03:49 PM
zinger11
Dec 19, 2011 12:35 PM
Q8y_drifter
14
Jun 14, 2010 06:59 PM
FIFA RACING
Misc. Vendor Items
Feb 12, 2010 04:24 PM
