Help Tail lights or brake lights on after car was off. Drained battery
Old Aug 26, 2023 | 03:32 AM
TheRob's Avatar
TheRob
I came home and parked the car and later was told by our kid that my lights were on in the back of the car. I went out, checked it and immediately had zero power. Put a jumper box on it, started up but the rear lights and third light were on. I pressed the brake pedal and they aren't lighting up.
I pulled the STOP fuse and the lights cut off. Fuse looks fine though. Considering this was 2am, I wasn't able to really go over solutions. I've read about the pedal switch grommet and to check the tail light fuse behind the battery which I'll certainly do in the morning. Any other things I should try?
Short of that, with the STOP fuse pulled, I'm assuming it's something brake related. I can't drive around with no brake lights obviously. Just wondering if this is common and a simple fix before I start tearing into the car.
2009 G37xS
Thanks for any help/suggestions.
Old Aug 26, 2023 | 09:00 AM
socketz67's Avatar
socketz67
Community Builder
Are you able to recreate the problem? Does it occur if you turn the switch on the steering wheel switch on and off manually vs. set to auto? If you lock the car using your keyfob, do all the lights go off? Is it possible that the rear lights left on are the brake lights vs the tailights?
Old Aug 26, 2023 | 12:29 PM
TheRob's Avatar
TheRob
It won't recreate. Fuse is fine for the STOP in the kick panel. Just constant on lights if I put the fuse back in. Arming the alarm, lights stayed on again.
Old Aug 26, 2023 | 12:38 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by TheRob
...started up but the rear lights and third light were on. I pressed the brake pedal and they aren't lighting up.
Because you are confusing your PARKING LIGHTS with the BRAKE LIGHTS. If the 3rd brake light is ON then your brakes are "applied." The parking lights are a lot dimmer than the brake lights.
And you checked the brake pedal switches?
Old Aug 26, 2023 | 12:44 PM
TheRob's Avatar
TheRob
Funny you said that I just noticed that the little grommet that pushes in to engage the brake pedal switch was basically hanging off to the side a little bit and smushed. I'm not sure what the official name for it is but I'm on my way right now to the auto parts store to try to get another one because I can't even put the car in drive.
Old Aug 26, 2023 | 12:47 PM
ILM-NC G37S
Here is what you need: Rubber Stopper. The chain stores might have something similar/ or useful.
Why not just glue your old pad back onto the tab?
Old Aug 26, 2023 | 12:50 PM
TheRob's Avatar
TheRob
This one wasn't rubber it was very hard plastic and forever reason it was bent sideways where it looks like the clip broke off on one side. I don't know how it got that mangled
Old Aug 26, 2023 | 01:01 PM
ILM-NC G37S
...I don't know how it got that mangled
You would be surprised, my friend, lol...
If you can rig up any solution so that when the brake pedal is released the plunger on the switch is pressed in, everything will return to normal.
Old Aug 26, 2023 | 01:03 PM
TheRob's Avatar
TheRob
I was trying to be creative but I'm in a hurry cuz I'm supposed to be at an appointment 45 minutes ago so unfortunately I'm heading over to the dealership to see if they've got that stupid little part and if not do you have any ideas of what I could get at like home Depot maybe because mine was hard plastic and not rubber and it was very very small compared to the ones that they sell at the auto store
Old Aug 26, 2023 | 04:00 PM
TheRob's Avatar
TheRob
I ended up having to go to the dealership and paid $15 for the grommet for the brake pedal. I tried Autozone and NAPA. Napa had one that I bought for $6 but it didn't fit. I'm back to driving thankfully.
I appreciate those who chimed in. Thank you very much.
Old Aug 26, 2023 | 04:04 PM
TheRob's Avatar
TheRob
Amazing this was $15 with a retail of $25.36, I got 15% off so like $12 and change. Dealership is such a ripoff but I had no choice I guess.
Old Aug 26, 2023 | 04:40 PM
ILM-NC G37S
You are lucky that the part was even available at your dealership let alone on a Saturday.
Either way, glad to hear you are up and running.
Old Aug 26, 2023 | 05:02 PM
TheRob's Avatar
TheRob
I feel fortunate, for sure. Amazing that such a small part can literally disable a vehicle. Unreal. Thank you.
xjbilly
Apr 7, 2024 10:20 AM
STOOF
General Tech Questions
Jan 28, 2019 05:08 PM
arbelaezr
May 31, 2014 10:31 AM
Nats G37s
Oct 17, 2012 06:54 PM
