7AT transmission compatibility questions
Old Oct 26, 2022 | 02:00 PM
Akeem175's Avatar
Akeem175
So about 2 weeks ago my car started stalling at stops, or when I put it in gear R or D. I did the usual troubleshooting and cleaning that's recommended, throttle bodies, MAF ETC. Yeah didn't solve the problem, so my transmission is basically dead torque converter etc. Absolutely refuses to go into gear. So I'm looking to swap in a different used 7AT G37 transmission but the more I look the more questions I have.
1. My car was built 3/13, but a lot of the transmissions im seeing are marked as thru 1/13 and from 2/13. If i did get one of the ones marked 1/13 will there be any major problems or issues? Are they different from the 2/13 and onwards ones?
2. The vast majority of G37 7AT transmissions im seeing are for the X models, AWD. My car is RWD. The back of the transmissions are noticeably different. My question is, if I did get an AWD would I be able to swap my old transmission rear onto it to convert it to RWD?
Old Oct 26, 2022 | 03:07 PM
BULL's Avatar
BULL
Moderador
Converting is a no-go. The case is physically different.
As far as the transmissions go there's really no tell tale since they usually lock the TQ or give up a gear.
I would try to stay between 2010-2013 G37 or a 2014-15 Q40 7at (same as G37)
Other than VIN confirming the miles and physically checking the fluid quality there isnt much you can do. Id suggest a place that is willing to offer some sort of warranty.
I have a Base transmission in my sport and never had any issues.
Old Oct 28, 2022 | 01:13 PM
Krzysztof47's Avatar
Krzysztof47
You might want to plug your VIN into a site like Infinitipartsdeal and see what exact transmission your car was made with (Part Number). They actually have a lot of different part numbers for the 7AT, they are not all the same like most think.
SoutherTierVQ
Jun 30, 2021 09:07 PM
ZahyMatar
40
Nov 29, 2017 10:42 AM
Fico
Aug 20, 2013 07:58 AM
YetiTL
Sep 16, 2011 12:35 PM
RhiNoKiLL
Sep 18, 2010 02:00 AM
