Help G37X 2011
Help G37X 2011
HI everyone.
Ok something weird happend. I drove the car all day it was fine. I went out to eat for an hour came back and the check engine like can one when i started it up. I started drving and it shifted hard into drive. It was then stuck in second gear. I drove it about a mile and pulled into a parking lot and backed in and turned the car off. Now the car will not start. it will turn on and power everything but when you press the brake and the ignition there is nothing. and the key light is on in the dash. Any feed back
thank you,
jay
thank you,
jay
HI everyone.
Ok something weird happend. I drove the car all day it was fine. I went out to eat for an hour came back and the check engine like can one when i started it up. I started driving and it shifted hard into drive. It was then stuck in second gear. I drove it about a mile and pulled into a parking lot and backed in and turned the car off. Now the car will not start. it will turn on and power everything but when you press the brake and the ignition there is nothing. and the key light is on in the dash. Any feed back
thank you,
jay
thank you,
jay
It was the TCM (transmission control module) for me, very expensive and requires reprogramming, new lower transmission pan gasket and new fluid. I had a place do it that was able to do the job and program it without the dealer. I know most will say steering lock but figured I would let you know as it seems somewhat similar to what happened to mine. Granted I could not drive it so I didn't experience what you describe of it getting stuck in a certain gear.
Hope this is of some use to you, and that you can get this resolved.
tigran199102
11-06-2023 04:56 PM
