Nismo away bars with g37x end links
Old Jun 2, 2020 | 02:56 PM
Bluecheese's Avatar
Bluecheese
Nismo sway bars with g37x end links
Hi guys!
new to the forum and excited to be on here. Been doing a lot of reading and it seems like you can install the 370z nismo away bars on the 37x sedan. I found a set of nismos that are clean but do not have end links on them. Can I use my stock end links with these bars? I have a 2011 37x sedan.
thanks!
Old Jun 2, 2020 | 05:42 PM
Bluecheese's Avatar
Bluecheese
Sorry, sway bars*. Stupid auto correct
Old Jun 3, 2020 | 10:07 AM
Surfnazi's Avatar
Surfnazi
no you'll need adjustable ones
Old Jun 3, 2020 | 03:43 PM
Bluecheese's Avatar
Bluecheese
Thanks for the reply surfnazi. I ended up picking up a RSB from a RWD g37 so simplicity sake.
Old Jun 3, 2020 | 08:10 PM
Adamz28's Avatar
Adamz28
Can you say more about this? I thought these were interchangeable across the G37 and 370Z platforms. Thanks!
Old Jun 3, 2020 | 08:29 PM
RMB5190's Avatar
RMB5190
They are. I ran a Z sway bar on my X endlinks for 50k+ miles.
Old Jun 3, 2020 | 08:38 PM
FreightTrain's Avatar
FreightTrain
End links will work fine. You'll need the larger brackets that come with the rear sway bar, or buy aftermarket ones that will fit.
Old Jun 3, 2020 | 08:49 PM
Adamz28's Avatar
Adamz28
I hadn’t considered that. Would that include larger bushings? Thanks.
Old Jun 3, 2020 | 09:03 PM
Adamz28's Avatar
Adamz28
I found this in another post. Looks like the same part numbers for AWD and RWD RSB brackets. Makes me think the 370 might be the Same size bracket. Would the larger rear bar diameters (17mm vs 24mm+) Require different bushings?
Bracket
L: 54614EG000 R: 54614EG000 AWD
L: 54614EG000 R: 54614EG000 RWD
Old Jun 4, 2020 | 07:59 AM
RMB5190's Avatar
RMB5190
Definitely. I think when I got the bushings the brackets came with them but the bushings need to be replaced. The Z/RWD G37 sway bar is too thick for the AWD bushings.
I want to say I tried a test fit of the Z bushings in the AWD brackets and it was a no go but I can't quite remember. I'd go with brackets to be safe. I think I paid all of $20-30 for them with the bushings.
AUtigers350z
Jun 15, 2014 12:12 AM
AMai1215
Oct 6, 2012 10:04 AM
RonMJ
Oct 5, 2012 08:40 PM
pierre3101
27
Jun 2, 2011 01:07 PM
