Sway bars any help?
Old May 3, 2020 | 10:26 AM
BillyTheMan's Avatar
BillyTheMan
Sway bars any help?
I'm going to be buying a set of hotchkis sway bars and my friend seems to think it won't be a very noticeable difference, not worth buying. What do the you guys who have them think?
Old May 3, 2020 | 01:52 PM
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Give the forums a search. This question is as old as the v36 platform lol. Its one of the best bang for your buck upgrades you can do for your car.
Old May 3, 2020 | 04:00 PM
BillyTheMan
I've looked at quite a few threads on here. I guess from his point of view the car handles pretty good stock is it worth $440 for it.
Old May 3, 2020 | 04:03 PM
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Yes. 100%
Old May 3, 2020 | 06:07 PM
Conboss's Avatar
Conboss
Instead of an aftermarket part I plan on getting a rear sway bar from a sport model. I have an X with the thickest front bar but it’s just a bit too messy. It would tighten everything up
Old May 3, 2020 | 06:32 PM
Worth every penny and then some. It's a no-brainer decision. Best bang for buck mod on this car.
Old May 3, 2020 | 06:51 PM
iCrap's Avatar
iCrap
It's one of the best cheap mods for almost ANY car
Old May 3, 2020 | 08:47 PM
BillyTheMan
I guess it's harder to know how good they are without using them. An exhaust you can see video for how it sounds, and hp upgrades you can see. sway bars you have to feel yourself. Anyway thanks for the input, I'll keep those on my list.
Old May 4, 2020 | 01:57 PM
jpowersjr2's Avatar
jpowersjr2
Don't listen to them for car advice lol.
Research on the forums thoroughly. There is a TON of useful info on here. Like everyone else said, best bang for the buck. The car is a boat stock. Mine handles much better now. Granted, I have a ton of other suspension mods as well but body roll is significantly reduced.
Old May 4, 2020 | 07:24 PM
gokano's Avatar
gokano
BillyTheMan: I have the Eibach sways and it was a very worthwhile mod for firming up the suspension. You didn't mention if you have the stock suspension or aftermarket but if you are stock, aftermarket sway bars like the hotchkis and eibachs will tend to be even more noticeable due to the softness of the springs/shocks relative to most aftermarket. suspensions. also, the more adjustable the sway bars are, the more flexible they will be to meet your preferences in handling i.e. multiple holes on the bar ends where the end links attach.
Here's a good thread that goes into some detail comparing aftermarket sway bars:
https://www.myg37.com/forums/brakes-...ay-bars-2.html
Old May 4, 2020 | 09:47 PM
Jackfriedman's Avatar
Jackfriedman
I just installed the hotchkis sway bars this weekend and man did it make a difference. I’m currently lowered on Truhart coilovers quite a bit to the point where sometimes on hard corners my front would rub the plastic liner. The coilovers I have were a bit bouncy and these sways have gotten rid of the bounce. I feel very planted with little body roll. I’d suggest going for them! I also have the rears on the middle setting.
Old May 9, 2020 | 02:43 PM
slovell1's Avatar
slovell1
I put Eibach bars on my 08 coupe and they made a very noticeable difference even on their softest setting. My car is much more stable in corners now with a firmer ride. Money well spent.
Old May 9, 2020 | 03:42 PM
When my car was new and all original parts, meaning RWD with LSD and staggered summer tires, it would always understeer on a hard turn. It didn't take much. Swaybars installed, problem solved.
Old May 9, 2020 | 06:32 PM
sl33per's Avatar
sl33per
sways are definitely a great upgrade - look into eibachs & you'll save about 50-75 per bar. makes a huge difference with curves / turns / bodyroll
Old May 9, 2020 | 11:38 PM
KImChee's Avatar
KImChee
Definitely worth it especially if you have an awd and you're upgrading. Car is much more neutral and planted with reduced body roll.
vquezada24
Jun 26, 2015 09:33 AM
JEBperformance
Brakes/Suspension
Nov 30, 2011 02:10 PM
